Weltmeister rear sway bar replacement parts?
Hi, does anybody have an idea where I could pick up a piece for a weltmeister rear swaybar? The piece I am looking for is the drop link attachment to spring plate assembly that replaces the toe link adjuster (sway away spring plate).
Thanks for any ideas.
J Mac Current 0 Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified |
part circled in red
To answer my own question I was able to order the eccentric bolt marked F in the diagram by going through the Eckers website.
As I recall, the remaining parts contain SAE threads and can be sourced from many vendors. Part P is a clamping bolt, I believe 1/4-20 or 28 and borderline tiny for a suspension component. Thus, suggest a socket head version (typically 180 MSI). FWIW, I believe Tarrett takes a larger 3/8" thread for their sway bar pieces, including their version of part F.
Sherwood |
Retired Member
Pelican sells the part. It's not on the site, but if you called them they would have ordered you one.
That's what they did for me.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
I called them and was directed by them to "automotion"......go figure
Might try *****************..the seem to deal with weltmeister
Paragon Products was very helpful to me recently when I needed a Weltmeister part. R/Dave
Yes I was able to get some fairly obscure Welmeister sway bar parts from Paragon
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
