1977 911 seat spring/handle
1977 Porsche 911 driver side seat
Can this spring be replace with out replacing the whole handle ![]() ![]()
A couple more pictures of the whole handle, bracket and spring. The spring is broken and the handle don't seam to slide out to put in a new spring?
Yes there 2 small springpin one is holding the spring tension your spring look ok or is the pict angle. look like one pin is broken.pm me i have a couple slider.
Thanks for the info. The spring is broken one end of it. What do you have?
