Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Relocating Battery to Smugglers Box - Which Battery To choose?
Hey folks,
I'm going to embark on a little project of relocating my battery to the smuggler's box. Can you recommend a good lightweight battery to use?
Thanks!
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 11-21-2011, 02:20 PM
m1franck's Avatar
Odyssey 925 lightweight battery with a relocation kit from Rennline. Relo kit available from our host.
Old 11-21-2011, 03:04 PM
Garage Queen
PorscheGAL's Avatar
MTO,
I'm using a red top Optima in the smuggler's box. What means are you planning on holding the battery in place?
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 11-21-2011, 03:06 PM
Rennch on YouTube
rennch's Avatar
I'm going to fabricate a holder for the smuggler's box. But that's perfect...the red top Optima is a great choice. I've used that Odyssey 925 too...so I might check that out as well.
Michael O'Neal -
Old 11-21-2011, 03:08 PM
Garage Queen
PorscheGAL's Avatar
I like that better than an Optima set-up.
Stephanie
boba's Avatar
Another Rennline and Odyssey install.
Old 11-21-2011, 03:37 PM
mack6820's Avatar
Whats the benifit of relocating the battery? I considered doing it too for weight distribution, but does it really make that much of a difference?
Certified Southern Dumbass!
83 911SC with 993 conversion,
98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
Old 11-21-2011, 05:51 PM
m1franck's Avatar
"Whats the benifit of relocating the battery?"
I just don't like junk in my trunk!
Old 11-22-2011, 09:01 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Odyssey 680 is even smaller and still works fine in terms of load capacity. Had it in my '87 for a while and then moved it over to the '79 race car. Keeps on truckin', despite its small size.
Kevin L
'86 Carrera "Larry"
Old 11-22-2011, 09:09 AM
I just installed the Odyssey 1200mjt in my 88. I used the Target cutting board mount and a new ground cable.
PC 1200MJT Specs:
1200 cranking amps for 5 seconds
1090 cranking amps for 10 seconds
900 cranking amps for 20 seconds
Short circuit current over 2600A
44 amp hours
78 minute reserve capacity with 25amp load
With metal jacket and SAE automotive terminals
Length 7.87"
Width 6.66"
Height 7.55" including the terminals
Weighs 38.2 lbs
Old 11-22-2011, 09:19 AM
73 911 3.2
Patrice911's Avatar
I got the PC625 on my car for 4 years now. Last Saturday it was below 32F at the race track in the morning and it started the car with no problem.
Here some spec.
Patrice
1973 911 3.2 former track and AX car.
2016 VW GTI S PP
Old 11-22-2011, 09:38 AM
Platinum Member
dad911's Avatar
Wow. Nice.
Old 11-22-2011, 11:33 AM
I was wondering the same thing. Seems like the weight redistribution is in the wrong direction; I would think it better moved forward and down rather than backwards and up. There is a slight reduction in polar; very slight weight savings in copper wire....
'69 911E 2.7MFI ;996TT;987.2 CaymanS
'71 Volvo P1800E wife's; AMG SLK wife's
'71 Volvo race car
944S; 986S ; 734WHP drift car (son's)
Old 11-22-2011, 11:35 AM
ShakinJoe's Avatar
Deka. Cheaper than odyssey and it is same as Braille just rebranded.
Less than $100!!!!
'87 Carrera - 2400 lbs of Track Beast!!
'88 Carrera Cab - Too nice for the track.
'85 Targa - Salvage title that was not caught!
Old 11-22-2011, 01:42 PM
Rennch on YouTube
rennch's Avatar
I've heard that. Which deka do u like?
Old 11-22-2011, 01:53 PM
ShakinJoe's Avatar
I use the Deka ET20XL because it uses the Braille uber cool aluminum mount.
This is old pic of my old DEAD Braille. I moved the battery to passenger side and added a cutoff switch.
Second Pic is Deka next to Braille....they are the EXACT same size....and I mean EXACT.
Old 11-22-2011, 02:11 PM
The biggest gain is probably moving 40 pounds of weight off of the heavier left side of the car. It helps offset the weight of the driver.
JR
Old 11-22-2011, 02:22 PM
Rennch on YouTube
rennch's Avatar
Excellent...I think there's a local supplier of Deka in Denver too. That Braille mount is very cool...
Michael O'Neal -
Old 11-22-2011, 02:25 PM
Rennch on YouTube
rennch's Avatar
Deka looks like the way. There's a distributor called Hensley battery in Denver that carries hundreds of them.
Michael O'Neal -
Old 11-22-2011, 02:33 PM
JR
Just wondering if the same light battery placed in the right side front box is better or worse balance than smugglers box. (I run only 1 stock battery)
Is this a "cool" modification or one based on performance?
'71 Volvo race car
Old 11-22-2011, 02:35 PM
