Which Pulley Wrench
Hello all, so my fan belt isn't squealing, but I have almost an inch and a half to two inches of give and it looks kind of old, so I want to change it. Few questions, I've read through the writeup on Pelican and a few other threads.
Picture of my pulley below Cheers, Martin
1986 Carrera Coupe - 1987 W124 300E - 1999 Land Cruiser 100 - 2021 GLA250 |
Half moon with a single stud, that is what you need
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Where does it hook?
The slots over the belt?
'78 911 Coupe
Here is a link to the wrench you need:
Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI ![]() |
Racer
No. The single hole right over the nut you see at 1 o'clock in your photo.
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
lol
Holy crap, how did I miss that.
martin: re shims -- presume you can't disassemble the pulley without the wrench -- shims between the pulley halves help spread the pulley halves and make the belt looser. If you had no shims, your pulley would be at its tightest possible setting. Shims are pretty small and, if you can't remove the pulley bolt, I'd bet they're hiding behind the bolt.
I'll have a look when I yank it off over the weekend. Just need to get the pulley wrench.
83 911 Production Cab #10
The shims are hidden by the large keyed washer.
There is six of them and they could be distributed as 3 on each side of the half pulley or 4 in front and 2 behind. Remember how they are distribute when you take them appart. ![]()
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Hey all. Thanks for the tips. I guess I won't know until it comes off! 710 is the right size?
Member 911 Anonymous
Yes, 710 is the OEM size but:
Porsche is just under 710MM (3 in 3 out) a real PITA to align the shims due to tightness Conti Belt is 712-14MM+/- (1 in 5 out) Adjust as needed.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Belt adjust this may help
Martin,this may help when you start. Get a piece of 1x4 lumber about 4 inches long
and place this down on left side below cross member--see photos, then use a good tool set and 15/16 socket ,i have found over the years that the factory 24mm can slip and give you nasty skinned knuckles. This method you only have to hold one tool at a time and is very easy.The reverse to tighten. |
Took me a sec
Took me a sec but now I see the wrench pressed up against the block of wood. That's a really good idea actually.
I was going to use a regular socket or breaker but I actually thought the impact wrench might be better? Less twist?
Maybe it's just me, but I don't use a spanner to remove/install the fan belt.
I use an Allen wrench on the alternator spindle and an open end wrench on the nut... HTH, Chuck.H '89 TurboLookTarga, 425k miles |
Thanks, Rich
Looking for a 1970-1973 911 coupe, no sunroof. Matching numbers and originality are unimportant. |
hi,there is nice original close to you kinda;-)
ebay...122555455108 Ivan |
Those 2 links may help
http://forums.pelicanparts.com/porsche-911-technical-forum/842723-anyone-elses-fan-belt-keep-getting-loose.html http://forums.pelicanparts.com/porsche-911-technical-forum/830624-dealer-alternator-belt-way-too-small-tight-9-5-x-710-a.html
1986 Bosch Icon Wipers coupe. |
Martin... If you're pulling fan, suggest putting antiseize on shaft. Makes it much easier to pull fan downstream. There's a woodruff key on alternator shaft---watch for it as fan comes off shaft. Chances are that key will remain in place... also chance it might not.
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Put grease on the shims and that will hold them together as you assemble the pulley half.
Bruce |
Immature Member
1984 Carrera Coupe = love affair 1997 Eagle Talon Tsi = old girlfriend (RIP) 2014 Chrysler 300 AWD Hemi = family car "Lowering the bar with every post!" |
