Post picture post
ok, for me and the other computer neophytes out there, what is the procedure, in layman's terms, to put a pic in our post? like every little detail, right from the scanner to the bbs. i'm getting a headache trying to figure this out. it can't be this difficult. like what's copy and paste? what's the little green code and what do you do with it?
[This message has been edited by john walker's workshop (edited 06-02-2001).]
Old 06-02-2001, 03:07 PM
Senior Member
Superman's Avatar
Post
I wish I could help you John, but I'm like you. Somebody help this guy...I want to see the '73 Speedster.
'83 SC
Old 06-02-2001, 03:41 PM
Mrdi's Avatar
Wink
Hi Jon,
Start a new post with one sentence.( See Porsche go )
Copy- first you have highlight the new sentence-Push the left hand button on your mouse down and drag it acrooss the new sentence(See Porsche go). This makes the words a highlighted Dark blue shadow color. When they are this blue color then go to the toolbar( words on the top of the screen) to the word that says "EDIT". Click on edit then some other words come up, one is "copy" and one is "paste".Click on "copy".
This means the computer remembers your few words.
delete or erase "see Porsche go", then start a new sentence. When you're a few words into the new sentence go up to the toolbar, click on "edit" and then click on paste. The words the computer remembers will appear as part of your sentence.
Try this and the we're half way there.
Mrdi
Old 06-02-2001, 04:04 PM
Post
John,
Finaly something I can help you with....
Here is how to do it...
1. Click the link below "Insert an image into your post. " (right below the message window.
2. That will pop up a new window.
3. Click the "Browse" button. This will pop up the windows file manager, then select a file by clicking on it, and hit the "open" button. (files must be .jpg or .gif and not over 50k in size)
4.Click the upload button, and file will be sent to pelican, if you get an error message, like file to large. You will have to select a smaller file.
5. Place your mouse pointer in front of the "<" part and click the left button and drag (highlight) the entire line of text, till you get to the other ">" symbol. You can copy by, eather right click the highlighted area, and selecting "Copy" or by holding down the "ctrl" key while pressing the "C" key.
6. To paste the image in the message, just click inside the message box where you want it and hold the "ctrl" key while pressing the "V" key.
Then hit "submit Now" as normal...
Randy
Friends don't let friends drive RICE!
1978 911 SC
[This message has been edited by kamikazepilot (edited 06-02-2001).]
Old 06-02-2001, 04:05 PM
Bill Verburg's Avatar
Post
this is a test >
[This message has been edited by Bill Verburg (edited 06-02-2001).]
Old 06-02-2001, 04:09 PM
Post
On my first try I didn't see the "less than sign" img. this is painfull even trying to describe what to do.
Old 06-02-2001, 04:13 PM
Post
ok, i'm getting there. how to make it bigger and stay within 50K? thanks for the help. i'll be a whiz in a few years.
Old 06-02-2001, 05:15 PM
Post
I have a question that falls in with JW's picture size? What settings or parameters should I use for scans to get a photo that is large enough and has decent image quality,and still under 50k file size??
david 89 turbo cab
Old 06-02-2001, 07:02 PM
wckrause's Avatar
Post
A 4x6 photo, scanned at 150 dpi, 24-bit true color saved as a .jpg should give you what you're looking for. Some apps will allow you to select the quality level of the .jpg compression which will trade off file size for image quality. You can play with this setting to get the size below 50k.
If you're having trouble getting the size below 50K, email me what you've got and I'll give it a try.
williamkrause@icqmail.com
Bill Krause
'79 911SC Euro
Old 06-02-2001, 07:19 PM
Post
I use JASC Photoshop 7 for all photo editing jobs, it allows 1 button resizing to reduce to the 50k limit, the photo above was originally ~300k. Picture It also is reccommended by folks whose opinion I respect. I also have Adobe Photoshop 5 which allows a 2 step pixal reduction (both pixals and size are independanly done) but have found it cumbersome and difficult to get a good copy, it also likes its own .psd file format(rather than .jpg which is the best format to use). This can be a pain. Try to stay away from .gif as it is more limited in its color depth, often leaving a surreal and or grainey effect to the pic.
You are also going to be limited by the quality of your scanner. I have found it difficult to get good quality and large sizes from scanned images. I use a 5yr HP which is a dinosaur compared to newer ones so maybe thats the problem.
Best images come from a digital camera all of mine are either from a Nikon 950 !$750 or a Canon S100 ~$420. I really like the Canon, its small size mean that I have it with me much more often.
Old 06-02-2001, 07:33 PM
Post
Another try...
Jens
[This message has been edited by Jens Wendorff (edited 06-05-2001).]
Old 06-05-2001, 01:37 AM
Post
Old 06-06-2001, 10:35 PM
CrazySOB's Avatar
Send a message via AIM to CrazySOB
Post
testing
Old 06-10-2001, 05:23 AM
Post
To make it possible for forum participants to access a picture-laden thread, please limit the dimensions of your uploaded scans. With my 52K dial-up modem, it takes forever to access the contents of a thread when it's filled with giant photos (really unnecessary). I actually bypass the long threads and go on to something I can see right away. Have you ever been to a website where the home page takes minutes to load? People tend not to stick around too long if the page is more than 60k in size or so.
Compose your digital files to no more than 72 dpi (this is the best a computer monitor can resolve) and a "comfortable" image width of around 600 pixels. Bill Verburg's silver targa is 672 pixels wide and 72 dpi. Big enough, sharp enough, and it's 48k in size. For comparison, Jen's picture is 1334 pixels wide. People prefer not having to scroll to see the entire image.
In addition, use the jpeg compression format for halftones (read photographs) or any image with continuous tones in it. Jpg provides several different compression formats; more compression = smaller file size = less color/detail. Use the gif format for images that contain only solid colors with no color gradations. For example, the message icons are all gif formatted art (e.g. line art).
I hope this helps,
Sherwood Lee
http://members.rennlist.org/911pcars
Old 06-10-2001, 10:39 PM
Administrator
Jack Olsen's Avatar
Post
And also: do not upload an image with spaces in its file name. Change:
to:
Before you try inserting it into the post. Those of us who use Netscape can not view posts with images that have spaces in the file names.
Jack Olsen
My Rennlist home page
My Pelican Gallery page My Porsche Owners Gallery page
[This message has been edited by JackOlsen (edited 06-10-2001).]
Old 06-10-2001, 10:54 PM
Early_S_Man's Avatar
I have mentioned this in other graphics/pic threads, but just in case someone missed it ...
Anyone with digital camera or scanner software that came 'bundled' with them, and unhappy with the capabilities or difficulty using the package, and no intention of spending $100 or more on commercial graphics software ... should get the FREE download of Irfanview at the link below:
http://www.zdnet.com/downloads/stories/info/0,,000ABJ,.html
Because it is a very small program, 630K, it loads incredibly fast, and takes up minimal disk space. It also can be used to crop out unneeded background area out of pics, and JPG compression can be varied as an option during a 'Save As' file operation.
I can reduce a scanned image from my 10-year old HP Scanjet IIc scanner that started out as a 2.0 MB file down to under 50K very easily in under five minutes in four or five 'experimental' saves in a Irfanview 'Save As' operation varying the compression ratio!
Warren Hall
1973 911S Targa
Old 06-10-2001, 11:27 PM
JF JF is offline
JF's Avatar
Post
Ok guys, I can't seem to get this...
But here goes...
Nothin'. =(
[This message has been edited by JF (edited 06-20-2001).]
Old 06-20-2001, 01:39 PM
Post
Ok.....I'll try...
Don't think so...
Old 06-20-2001, 05:56 PM
Post
Well....
I guess it did!
Thanks to all for the help!
Eric
Old 06-20-2001, 05:57 PM
