Parking brake warning blinking
On my 1973 2.7 911. My hand brake warning light blinks continuously.
I guess it could be the hand brake switch adjustment, and I have not checked that out yet. When I push hard on the brake pedal when the car is stopped the light will go out for a minute or so, but usually come back on. What is in this circuit? I have studied the wiring diagram, but I have not found any ideas of what to trouble shoot. Thanks in advance for your help and ideas.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
push your handbrake down to see if it goes out.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
Senior Member
Fuzzy on this but it could easily be the master cylinder's brake switches (the ones activated by pressure via the brake pedal). I seem to recall they are wired iinto that circuit, but smarter minds will guide the way.
'78 Targa in Minerva Blue |
Brake fluid level ok?
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
Yes it could also be a failing Master cylinder
Dial 911
+1...This has happen to me on the odd occasion.
Cheers! “Simplicity is the ultimate sophistication.” Leonardo Da Vinci |
Dick:
I had the same problem a while back. When I removed the electrical connecter from the master cylinder the flashing went away except when I used the handbrake. You can access the switch by removing the left front wheel. Replaced the switch in the master cylinder and problem solved.
Thanks for all your answers......I will start by checking the master and the switches.....that is what I was suspecting.
Will report on what I find.
Speed Dog's Chauffeur
More than M/C on flashing light?
If not the MC. I have never seen a brake circuit warning light on my 73. There may be more than brake warnings on the flashing GEN/Brake light. Is it the top center light flashing? Low oil level is also tied into the flashing GEN light too. Kind of a catch all idiot light. A long time ago, I serviced a soldier's 73 MFI 911 brought back from Germany and it only had 3 quarts. A Porsche dry sump is worth every quart of the 10-12 at oil change. Best of luck.
Early 73 start with PET and keep eyes open
The owner came into the shop complaining of a generator light flashing on his early 70's Euro MFI 911 and it was low oil. Yes, I have the PET CDs & download the diagrams but I still have to perform due diligence if it is not an EZ fix. Follow the published info but do not wear blinders on early 70's cars. Just saying what worked for me back in the day. Just trying to add alternative avenues of tracing problems if the M/C is not the fix.
I know what I found in my 1973.5 and suspect the OP's is similar.
Update
On Sunday I did a bit of checking and found the brake fluid level low.....I do know that in this 1973 911 there is no way that would make the light flash.....but I did top it up.
Today I found some time to check the emergency brake switch......I removed the 3 bolts and raised the brake mount a bit. I really need to remove the seat to get in there, so I just un-plugged the brake light switch. That did nothing. Next I will check the master cylinder switch..... by the way I took the bulb out in the meantime!!!
You are duplicating my path to finding a bad switch on the master cylinder. I think you will find a bad switch.
As I mentioned it would go out with a hard push or 2 on the brakes.....it has stopped doing that now. Maybe I will have time this weekend. Will keep you posted.
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 Last edited by dicklague; 02-03-2017 at 01:00 PM.. |
Did you ever find the source of the problem?
