I changed the wiper track on my '85 to address the bucking issue and it did nothing. The SW chip is what cured it for me...
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow
Finally resolved
Not so fast...
The improvement didn't last long. Not sure why it improved at all considering the actual issue. Took it in for a valve adjustment (I hate doing those) and asked my mech to take a crack at it. It ended up being the crank position sensor gap. It wasn't close enough to the flywheel and was causing the jerkiness. He said that it came to him while he was in bed. He remembered back in 1984 when the 3.2 was new. He was in the Porsche engine class and the instructor told them that the motor would be jerky if the CPS-to-flywheel gap wasn't just right. He said you won't find this in the book, it was just a tidbit the guy threw out there. So, something to file away.
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
Nice bit of info to know.... As I didn't move the holder for my sensors when I changed them out on my '88, I didn't check the gap. Probably should have if it's that critical and related to a potential bucking issue.
He rebuilt the motor, so there's no doubt how it got into the offending position.
actually this 0,8 distance is mentioned in all books and technical specs..It is very important you have it correct.
here is some reading http://forums.pelicanparts.com/porsche-911-technical-forum/987382-help-1988-3-2-rhd-replaced-cht-speed-reference-sensors-now-engine-wont-start.html
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
