911 User
barndoor's Avatar
RED-RUF
'84 Carrera 3.4-280hp
'75 914 2.0 85hp
'60 BMW R69-34hp
'49 VW Bug-25hp
Old 06-16-2007, 07:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #701 (permalink)
pete917's Avatar
I was just reading through this ultimate RUF thread and must say its awesome.
I have just bought a pair of RUF bumpers and would be greatful if anyone who has gone through the fitting process could share a few tips. I particulary what to find out:
- what nerf bars to use front and back,
- who supplies the best nerf bars;
- where are the bumper fixing points and do they attach to the nerf bars;
- how best to fill the gaps between the bumpers and the body panels.
Many thanks guys
Pete
Any advicxe much appreciated.
Pete
Pete
Porsche, there is no substitute!
911 Coupe 1974 plus bits | Stuttgart eXchange | Channel P101tv
Old 01-24-2008, 07:19 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #702 (permalink)
shahram's Avatar
Pete, here you go:
- what nerf bars to use front and back & - who supplies the best nerf bars;
I did not use any nerf bars, it works perfect w/o any.
The ruf bumpers are bolted right underneath the fenders (front and rear bumpers) and are also bolted under the rear reflector and front hood right to the body.
front: the 964 smile (seal)
rear: original body seals are fine
Old 01-24-2008, 11:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #703 (permalink)
charleskieffner's Avatar
a real simple method on the nerf bars is to remove bumper shocks or even use them. if you want to retain bumper shock, cut head off and then weld some chrome moly from bumper shock to bumper shock. or remove bumper shock and build squared off hoop for yer nerf bars.
in the event of a low speed crash it can help alot. dont expect any miracles probably above 15-20 mph. but it is better than nothing and they do add rigidity.
Old 01-25-2008, 04:00 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #704 (permalink)
pete917's Avatar
thanks guys.
What about oil cooler behind the grill. Where did you mount that?
Pete
Old 01-25-2008, 10:16 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #705 (permalink)
Bill Verburg's Avatar
Originally Posted by pete917 View Post
thanks guys.
On mine I used stock non hydraulic(RoW) bumper mounts, back ones are used in front and the front ones were cut down and used in back to mount the nerf bars. I think it's a good idea to use them to shunt a frontal impact into the area designed for that purpose.
My oil cooler is hung from the front nerf bar. It's a regular B&B valance mount, fits perfectly
Bill Verburg
Old 01-25-2008, 10:23 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #706 (permalink)
if i had to do it again, i would mount one probably both hella fogs in the rear bumper. much cleaner, lots of room, easier to clean valance. the rear fog as we did it just seems to be sticking out in space by itself tempting fate to be crushed into lil itty bitty expensive pieces.
dont ferget insulation matting for your rear bumper inside to avoid bubbling yer paint from exhaust temps.
Old 01-27-2008, 04:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #707 (permalink)
wow, keep em coming, this thread is making me rethink my 911 plans!
______
Mark S.
White 1980 911 SC Targa
Old 01-27-2008, 08:45 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #708 (permalink)
pete917's Avatar
Awesome. Thanks. Can you share a little more infor the oil cooler. where you got it from, any pics, price etc. I also like the idea of the using the ROW bumper mounts.....any photo's of the nerf bar that you made up?
Many thanks
Pete
Pete
Old 01-28-2008, 03:25 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #709 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
Do an advanced search for "nerf" with Bill Verburg's name and you'll find some good pics of oil coolers and talk of the nerf bars.
Kevin L
'86 Carrera "Larry"
Old 01-28-2008, 06:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #710 (permalink)
Many thanks
Pete
Unfortunately I did this back befor digital cameras and haven't had to remove it since, so no pics.
I used the normal B&B valance mount cooler PEL-BBKT3
Rob Fussi did a similar write up on his install using the larger B&B
The small has worked well on mine w/ up to a 3.8 but for lots of track days in hot weather the biggger one is better.
The only isue is that I ordered mine w/ angled I/O, I think that the straight I/O is easier to connect.
Bill Verburg
Old 01-28-2008, 07:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #711 (permalink)
Rob's install
Bill Verburg
Old 01-28-2008, 07:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #712 (permalink)
pete917's Avatar
This has been really helpfull;. Thank you to all.
I've now received my RUF bumpers. I bought second hand so have a few fibreglass repairs to do to get them into top shap before fitting.
From the advice here, I've decided to go with a front smile from a 964, but fo the back I'm not sure what to use. With the bellows removed there will be a gap with no rubber gasket. Is there anything people have used that they can recommend here? Is there anything from a 964 that would fit?
Pete
Old 02-25-2008, 03:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #713 (permalink)
Wavey's Avatar
You can use some '76-80 930 bumper welting, Porsche part # 999 911 205 40. Comes in 5m rolls, which is enough to do both ends of the car. I think Pelican still carries it.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 02-25-2008, 04:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #714 (permalink)
since changed my exhaust to dual's, i have noticed various exit strategies for the exhaust tips.
i have already added mucho heat blanket material into RUF bumper to avoid paint damage. but what i have noticed in all the pics is a variance in length of exhaust pipes.
has anyone done any damage or discoloration on their RUF rear bumper valance from super heated exhaust marring valance, by cutting tips TOO SHORT?????
is there a certain length that allows no soot,discoloration to fiberglass area?
Old 02-25-2008, 10:55 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #715 (permalink)
pete917's Avatar
Thanks for the advice on welting roll. Will order that ASAP. I was also planning on using heat reflecting material to help avoid discolouration of the Fibreglass. I am also going to include an aluminium under bumper bar, which must help a little with absorbing the heat.
Pete
Old 02-25-2008, 01:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #716 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
How does the 964 smile attach to the bumper or chassis along the leading edge of the hood? Guys ask me if the hood goes under the lip in the seal and I tell them no. But I haven't received my front bumper yet to see how the seal attaches correctly. With no bumper or valance in place (front end is bare from the fenders down) I laid the seal around the perimeter of the fenders and hood. It fits perfectly along the fenders but I can't visualize how the 964 smile will lay on the bumper and meet the hood.
Thanks!
Kevin L
'86 Carrera "Larry"
Old 03-03-2008, 06:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #717 (permalink)
Thanks!
Along the leading edge of the hood I attached mine with some screws on the back edge of the smile. With the hood closed you can't see the screws.
You can see them in this pic:
Old 03-03-2008, 07:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #718 (permalink)
KTL KTL is offline
Schleprock
KTL's Avatar
That's what I thought, but wasn't sure since the 74-89 911 smile attaches to the tub and fenders. So I wanted to make sure for this installation we're attaching the smile to the bumper.
Thanks for the picture Scott.
Kevin L
'86 Carrera "Larry"
Old 03-03-2008, 07:30 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #719 (permalink)
williecoyote's Avatar
Scott, how does the hood close against the 964 smile? Does it pin the lip down on the smile? Or does the hood tuck down behind the lip on the smile? Or does the hood butt to the lip?
Did you have any problems with the hood closing correctly, as a result of the screw heads sitting up too high?
Will
85 carrera
Old 03-18-2008, 04:28 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #720 (permalink)
