Cruise Control Bowden cable
My cruise control Bowden cable has broken on my '85 911.
PP says it is no longer available. I have found it elsewhere for $133. for the assembly- the inner and outer cables, part no. 911 617 124 04. Has anyone had any luck with having just the inner cable made? I don't know what the drive link side looks like as I haven't taken it off yet. The throttle side looks easy as I think I could find a way to have a small. lead nub crimped on. Thanks. ![]()
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold |
I had to make all new Bowden cables for my HVAC. I found that a lawn mower throttle cable from Ace hardware is the same thing, has an S-bend just like my HVAC cables do on both ends. I ran new housing just because, and made the housing out of bicycle cable housings. Worked out great. You could source a lawn mower cable, and cut to length maybe?
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
(man/dude)
I extended mine with a $5 VW throttle cable clamp and a bit of stainless rod..... AFAIK you can't buy them new so your $133.00 one might not actually be available.
Maybe your local bike shop can make one for you?
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Yea, you may have found someone that says they have it. But don't count on it. I looked for a long time and even found a few parts brokers to search for it. It simple is not out there in any source I could find. If you can find a real source for them, please let me know. I would like a new one with a proper unbroken square plastic clip at the connection. Dual zip ties are OK, but the OEM clip is better.
I ended up getting one from on the Pelican Parts needed and for sale forum. Some people think it is useless and just adds weight, so they remove it and the AC systems. Anyone that actually drives on road trips will know it is wonderful to have. The end of mine snapped off, and I never could find it. I have no idea where it went. And be sure to use at least two zip ties to hold it in place. If it comes loose, it cause the throttle to go to WOT.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
I bought the $133 one but don't remember where. I was lead to believe it was possibly the last one in the U.S. They are 'rare as hen's teeth' -- as my dad used to say! Good luck!
Robert |
Recreational User
The only thing that's "Bowden" about it is that the cable rides inside a sleeve. Both sleeves and cables (or both) can be bought at any bicycle shop or motorcycle shop for just a few bucks. The cables come with a ball or barrel already attached at the end.
All: Thanks for the input.
I found the broken end on top of then engine under the throttle lever with a flashlight and magnet. I got lucky because I had a several hundred miles on the car after the cable broke. I will be looking at a bicycle shop or post a WTB add in the classified section. Again, thanks.
I used a guitar string to fix the cruise on my 85 911.
the end with the little knob works on the control module end, then I used a very small cable U clamp at the throttle end.
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
El Duderino
I thought the bowden cable was NLA too but I ordered a replacement last year from my local Porsche dealer. Pelican tried to order one but couldn’t. Maybe the dealer got it through Porsche Classic?
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
I got one through Porsche classic too from the local dealer. It took about 2 weeks to come from Germany.
Is this what you need? For sale at $70 shipped.
sandiego: Your ends do not match mine. I need what I posted in my pictures. I have an '85 Carrera.
Thanks.
I tried recently to get on through the Porsche Classic web site. It was not available. What part number did you have?
