Speedometer correction!
Well,
I had been unimpressed with my speedo accuracy from day 1. Didn't really wanna pay much to fix, and sending it into Hollywood Speedo every time I changed tire size was even less appealing. Found these chaps Down Unda, Official home page of the Yellow Box Speedo Recalibrator. Ordered one up and patiently waited until they strapped it onto a seagull and it got here(couple a weeks). Install was easier than a stereo, and calibration was very straight forward. The only downside is they speak Australian which is different than 'murican! Just kidding! I made my own harness so I wouldn't have had to cut my wires, easy peazy. Got it in and fired up corrected the already gps verified speedo error 11%. Went for a drive, crap no speedo, the sender uses 2 wires both brn/red, pulled over swapped them and bingo speedo! Verified with gps, spot on! 3.1416 banana job! http://forums.pelicanparts.com/uploa...1490654359.JPG http://forums.pelicanparts.com/uploa...1490654359.JPG http://forums.pelicanparts.com/uploa...1490654359.JPG P.S. As seen 4 wires +, -, sensor in, out to speedo. Basic stiff! |
OK now, this looks like a winner. Can you show a few more details on how you did this? I assume my '87 has the same sensor wiring set up as yours (2-wire inductive coil). How did you connect to the box with the harness you made (do you tap it at the trans, or at the speedo)? From the website, it seems like an electrical neophyte like me can even do this. Thanks for finding it!
Looks like a great solution. Investigating for purchase. Sent from my iPad using Tapatalk |
problem with mine, its a RUF, is it reads fine up to 60 then reads low to around over 100.
have not checked it at 150+, did not have the GPS in the car and have not been that fast in a while. its a good 5mph low at least at 80. |
I made a "harness" that taps into the existing wiring by adding a spade and 2 female crimp for each power connection. Its really so simple its goofy. Tap into the +, - terminals with the 1in 2out, part of the "harness", then take the sensor output and attach to the yellowbox input and attach the yellowbox output to the speedo. It is intuitive once you start looking at it. The speed compensation details are crazy accurate. The Aussie's love to mod their cars and this isn't really a suprise. |
I solved this problem (and a bad signal from my 915 tranny) by installing an AutoMeter GPS Speedo Sensor that is easily calibrated by hand. Its DOBA.......Dead On Balls Accurate. :D
how do these affect the odometer readings? Seem to recall that the speedo is optimistic by design/german law requirement -- but that the odometer is generally spot on. Would this mod make the odometer pessimistic?
Where exactly did you tap power from (looks like the Yellow Box needs a power source)? Not sure what you mean by "1in 2out". According to my schematic, the sensor wires into the speedo are brown (ground) and green (signal?). Did you do all of the splicing right by the back of the speedo, then leave the yellow box behind it in the back of the dash? (Their instructions indicate to do it down by the sensor pick-up at the trans, then run a cable all the way up to behind the dash, but this seems silly). Any photos for us that are electrically challenged would really be helpful. Thanks again... |
This looks expensive until you ask NHS to make the change (ask me how I know).
http://forums.pelicanparts.com/uploa...1491103307.PNG Note the colors and where the wires come and go to. The red/black stripe comes from the fuse box. The browns are ground The red/browns(2) come from the speed sensor, one comes from the sender and creates the pulses and the other one is the "ground" for the circuit. Neither wire carries any significant voltage or amperage so switching them around won't do anything other than cause your speedo to not work, until you switch them back. The power is required for both the speedo and yellowbox, hence the 1 into 2 pigtail. The ground is required for both the speedo and yellow box as well. It's actually easier than it sounds. The reason I did pigtails and auto spade connectors was to eliminate "splicing" The pigtails allow plug and play. |
Got my Yellow Box the other day, and installed it this evening. All I can say is YES!! My speedo is now dead-nuts accurate (had to make a 12.4% correction). What a great joy; the speedo has bothered me for years. Install was easy, as Click says above; very intuitive, and easy to program. Only difference from above is that my car is an '87, and the signal and ground wires are different colors from '83-'85 (signal is green, ground is brown). Great instructions to do various diagnostic tests, etc. At $93, it saved me hundreds, I am sure, from having to send to NHS. Thank you for finding this solution, Click. Even my wife wants me to give a shout out to you, 'cause she has heard me complain about it for so long. If any of you have a calibration issue with your speedo (electronic only, though), this is the ticket for sure.
Glad it was as easy for you as it was for me!
Hi I just received my Yellow Box and removing the Speedo I found it had 4 wires ,Red,Blue,Red/Black and a double Brown , My 911 is 74 but has a late 915 box with output to drive the electronic speedo which is 11%to high.http://forums.pelicanparts.com/uploa...1527937897.JPG
http://forums.pelicanparts.com/uploa...1527937938.jpg |
So their website says it produces a square wave and works with their speedometers, not with ones that expect a sine wave. Do our speedometers (I have a 1980 SC) expect a square wave?
Also, does this drive the odometer as well as the speedometer? Thanks! |
The electronic speedometer works by receiving 8 pulses per wheel revolution from the reed switch (puck) mounted to the outside of the transmission. There is a disk inside the transmission that has 8 magnets mounted to it. When a magnet is aligned with the red switch, magnetic flux causes its contacts make which provides a ground input to the speedometer. Inside the speedometer there is a pull up circuit that provides a 12 VDC signal input that gets interrupted to 0 VDC every time the reed switch provides a ground. So, this creates a square wave signal to the speedometer and odometer drive circuits. A speedometer calibrator intercepts the pulse signal from the reed switch and alters the pulse rate by a percentage to increase or decrease the pulse rate. For most Porsche speedometers, the pulse rate needs reduced because most read 5 to 7 MPH too fast. But you must check the speedometer readout a different speeds, because the speedometer may not be linear. My speedometer reads dead on at 60 - 70 MPH, but still reads a little fast at lower speeds after setting up a speedometer calibrator.
I fitted a Yellow Dog in 2012 or thereabouts; built-in period-correct legally-mandated optimism[*] with the extra inaccuracy added by 17" tires was really annoying... It was especially jarring/noticeable because the PO had adjusted the trim pot on the original speedo so it was dead-on accurate - but I replaced that when it broke the odo gear with 237K on the clock; every other factory speedo read much, much, higher and it was driving me crazy... Measured the rolling diameter, calculated the conversion factor/set the dip switches, made up a little spade terminal pigtail harness to provide power/intercept the speedo feed and tucked it behind the gauges. Checked it out against GPS, called it good... I'd actually completely forgotten it was still nestling in the dash just doing it's job, hadn't given it a thought in years/many 1000's of miles... Question that seems to come up is whether the electronic speedos/senders interchange; I've had everything from the '77, to an SC, 3.2 and a 930 speedo fitted - and went from a 915 to a G50. No difference that I could see. Also worth mentioning that if your speedo needle is erratic and you've checked everything else, the 100uF cap in the speedo board is known marginal - rated for 16V. If your voltage regulator has ever gone over-voltage.. The speedo will likely eventually fail entirely (mine did), but can behave oddly (like steady reading then drops down & back up a few seconds later) for years first... The cap can be easily replaced with a 50V part - old thread with bonus Early S Man content: http://forums.pelicanparts.com/porsche-911-technical-forum/247776-carrera-vdo-speedo-sucks.html [*] The Wikipedia article on speedometer accuracy https://en.wikipedia.org/wiki/Speedometer indicates requirements all over the map - so the factory likely just went with the Euro ones, as they were tightest... Current EU Type Approval regs state: Quote:
I too have issues with my Speed/Odo and looked into this company however they didn't answer any emails I sent asking for clarification on their product. Has anyone else recently heard from them?
Hope you can help a neophyte...
I have a 77 targa with 915 transmission. I am off by 10% linear (speedo reads high). I dont really want to drill into the speedo to adjust the pot..likes like giving a knife to a mass murderer. I assume I have a sensor on the transmission that picks up the pulse (should be a square pulse then) Where do you install the yellow box....behind the dash? Which wire goes where if I do, I can power source and ground easy enough...I figured if I could take the inbound to the speedo and re-route to the yellow box, then back to the speedo, I could even mount the box in the smugglers compartment or behind the blower. Click, Chris, 555......I am a pictures guy..any chance you can grab some photos of your set up and show me all the connections? so I get this right, Lyle..i got your PM..thanks rcraske@cogeco.ca Thanks |
also, which one is best for 77 targa with 915 transmission..sounds like the 2 wire splice is?
Yellow Box v5 - with Splice Wiring Harness Yellow Box v5 - with Custom Plug-n-play wiring harness* Yellow Box v5 "2-wire" - with Splice Wiring Harness (vehicles with inductive coil sensors only) |
The Yellow Box has a little brain in it. Needs power (5V or 12V), and ground. Intercepts the speedo signal, corrects according to the switch settings and outputs the corrected signal to the instrument. Very simple, very robust.
Everything you need in terms of connections is right there at the back of the instrument, no need to run any wiring anywhere. Dry, safe, concealed and protected nestling in the dash. The Yellow Box has a detachable harness plug with 4 wires coming off it. Installation manual here https://yellr.com/yb4_insta.pdf Couldn't be much simpler, if you can make crimped or soldered connections. Easily reversible, no need to cut factory wires. Disconnect the speed sensor connection to the speedo, use as input to the Yellow Box (i.e. put a male spade on the Yellow Box harness wire and plug the harness female spade into it). Put a female spade on the Yellow Box speedo output, connect to the speedometer terminal you just plugged into the Yellow Box. That's the intercept part done. 12V power and ground are right there on the back of the speedo; I just put female spades on the Yellow Box wires and used a male 2:1 female piggyback on the speedo terminals to supply both the Yellow Box and the original connection for both power and ground. Mark the tire (driven wheel). Measure one full revolution on the floor. Figure out the standard tire size for your speedo part #, calculate rolling diameter of that. Figure out the %-age adjustment between what you have versus what the instrument was designed for. Look the number up in the table, set the DIP switches. Pretty sure my adjustment factor ended up being nearly 15%. Drive the car. Check speed against a GPS or laser speed-trap, fine-tune until happy (e.g. adjust for any calibration error on your specific instrument, or calculation error earlier). I was happy as soon as I could drive the indicated speed limit and not get passed by every other car on the road - or drive with traffic and not have the speedo telling me obvious lies... The instruments themselves seem to be pretty accurate, up until it's a moot point/you're not really looking anymore... They just had to make them read fast for legal reasons (like everyone else). |
Thank you...sorry but a couple of more questions
which yellow box is the correct one to order? other then that which is the correct sensor wire to use since this picture shows two wires in http://forums.pelicanparts.com/uploa...1553618224.jpg |
I just had my speedometer calibrated by police. I was going 81mph in 50mph zone. The speeding ticket states I was going 81, although I did not disclose the number to the office.
[emoji354]4[emoji594] |
sorry, based on that picture..
take power from 2:30 o clock with piggy back connector take ground from brown (2 of them) at 5 oclock but this picture indicates two sensors..i assume #1 (B/R) is the target wire? |
What do these things cost?
According to this http://forums.pelicanparts.com/uploa...1553632153.gif one connection at the speedometer is instrument ground, the other is terminal 31b. Pretty sure I connected the Yellow Box to that. From https://yellr.com/yb_home.htm http://forums.pelicanparts.com/uploa...1553624515.gif |
Thanks ALL
I ve ordered and looking forward to posting success |
| All times are GMT -8. The time now is 07:10 PM. |
