VMAX1's Avatar
Valve adjustment with Kirk valve tool
purchased the Kirk valve adjustment tool, and that was Well worth the money. Might be one of the best P tools I have ever bought. I have done valve adjustments, maybe 5 times, but this tool is the tool! Professionals my differ with me, but I am not professional. Also, I always had a small leak around a valve cover, or covers, and got a piece of glass and some emery paper and went to work. No Leak. Amazing how things work out when you follow directions from our forum. Thanks to all that spend time sharing their knowledge!
Old 04-16-2017, 08:58 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Originally Posted by VMAX1 View Post
... but this tool is the tool! Professionals my differ with me...
They will... Please stand-by
Who Will Live... Will See
Old 04-16-2017, 10:48 AM
Perfect timing. I'll be doing my first ever valve adjustment and will be using the Kirk tool. I hope to report positive results like you did! Thanks.
Old 04-16-2017, 11:19 AM
Registered Minimalist
75 911s's Avatar
I've done about 5 or 6 valve adjustments as well. I made my own gauge, and then bought the kirk tool, which I have used twice now. It feels way more accurate in the phase of tightening down since you can see gap movement as you tighten. When using a feeler gauge you have to eyeball it and that's not so easy on the valves tucked back in the engine bay. If you're doing it with an engine drop, it's a push between a feeler and the kirk tool. I'd probably use both still.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Thanks for the report, I bought one and will be doing an adjustment very soon. I've done it the conventional way many times and it worked out fine. I like the idea behind the tool and it is very well made.
Rutager West
Old 04-16-2017, 12:05 PM
proporsche's Avatar
Hi boys..i have heard only good things about this tool ..personally i do valve adjustments without any gauges or feelers...just the hand feel worked for me ...since ever-1986.....
Ivan
Old 04-16-2017, 12:40 PM
iwhelan's Avatar
I too have this tool and love it. I never did a valve adjustment before doing mine last year, and it was great. Perfect results.
Old 04-17-2017, 07:10 AM
tobluforu's Avatar
Ivan
I'm guessing you are referring to the wiggle method? My good friend used this method for years, probably still does.
Old 04-17-2017, 08:00 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Additional fuel for the process:
http://forums.pelicanparts.com/porsche-911-technical-forum/846673-kirk-engines-valve-lash-adjustment-tool.html
BTW, still using the Kirk, don't know where the feeler gauges are anymore....
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 04-17-2017, 11:02 AM
proporsche's Avatar
hi toblu..i really do not know what is wiggle method i was taught by old-timer 911 mechanic this way so i got stuck doing it like this...
Ivan
Old 04-17-2017, 11:08 AM
VMAX1's Avatar
I would like to add, it was the best valve adjustment I have ever done. She runs a lot better and sounds like a sewing machine!
Old 04-19-2017, 07:00 AM
I use this method, but built my own tool. Works great
Very easy to do actually.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 04-19-2017, 09:15 AM
I'm another convert! I just completed a valve adjustment on mine using the Kirk tool and really liked how it worked. I've probably done a dozen or so with the feeler gauge and never felt like I knew if I was getting the right drag.
Well machined and made in the USA- very happy customer.
Rutager West
Old 05-10-2017, 03:06 PM
Fleabit peanut monkey
Bob Kontak's Avatar
When this guy talks, my ears are open Always a 0.004" feeler gauge guy but I listen.
1981 911SC Targa
Old 05-10-2017, 06:25 PM
JJ 911SC's Avatar
Originally Posted by Bob Kontak View Post
When this guy talks, my ears are open...
Good thing he was not talking about the Backside method...
Old 05-10-2017, 06:42 PM
Bob Kontak's Avatar
I swear to God, the amount of peeps that stray from the straight and narrow baffles me. To remain beautiful I have to adjust expectations in advancing years.
I do likes me some ClickClickBoom.
1981 911SC Targa
Old 05-10-2017, 07:32 PM
LakeCleElum's Avatar
After over 50 yrs of motorcycles and owing over 100 motorcycles. .004 and "slight drag" works just fine.....Never understood all the debate and drama?????
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-10-2017, 09:35 PM
What is a slight drag to some is not a slight drag to others. The Kirk tool is perfect.
Old 05-11-2017, 08:26 AM
Have been adjusting 911 valves since 1970. I always of course used a feeler gauge. A year ago I bought a Kirk tool and have retired my many somewhat bent and wrinkled .004" feeler gauges.
The Kirk tool to me is a well engineered precision tool and uses a long proven
and accepted principle. i.e. the pitch of a threaded rod can be used to determine
how far the rod moves with a given rotation. This is the very principle that is used
in a precision micrometer. It also is used in adjusting, with precision, the moving tool mount on a metal lathe. We all trust and believe in these precision tools, why not trust the Kirk tool to be MORE precise than a feeler gauge followed up by a subjective "slight drag".
The beauty of the Kirk is the adjustment markings on the tool are in essence the same thing as the measurement markings on a micrometer. I am a convert as the tool is much faster and less "fiddly" to use and more precise as well as being beautifully designed and crafted!
just my $.02 YMMV
Grant
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 05-11-2017, 09:03 AM
Taking it apart is easy
Jerome74911S's Avatar
For an extended review of the Kirk tool in action, check my blog:
Pondering Porsche(s): March 2015
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-11-2017, 10:39 AM
