New-ish 911SC Targa Owner
pampadori's Avatar
Help locating cooing fan extension deflector on back of alternator
I'm looking for the equivalent of part number 91110605501 but for my 1983 3.0.
I searched on the Pelican site but came up with nothing. Does anyone happen to know the part number for this item for my 1983?
I read thru a couple of posts and it looks like it's purpose is the cool cyl 1 and 2. I assume that makes this a critical part and I shouldn't skip it, correct?
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 04-22-2017, 02:25 PM
Don't know the part number but it's definitely critical. Try used parts classified.
Old 04-22-2017, 02:44 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Cooling duct.
Hope this helps.
Best,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 04-22-2017, 02:52 PM
I had the same problem for my -81 SC and ended up buying the one for the 3.2. I fits but you need to trim a little on the plastic by each screw to get it to seat properly.
Part # 91110605501
Gustaf
Porsche 911SC -81 Euro
Old 04-22-2017, 03:19 PM
And I believe that if you have the alternator with the built in voltage regualtor then the 3.2 version is the one you need. It has a notch for the regulator.
Gustaf
Old 04-22-2017, 03:27 PM
Alternator guide notch.
I had to extend the voltage regulator notch on the
air guide when I replaced the VR regulator as the new
regulator is larger than the factory original that came with the car.
Gerry
1986 911 Targa.
Only in L.A.:
Old 04-22-2017, 03:46 PM
Air guide.
1986 911 Targa.
Only in L.A.:
Old 04-22-2017, 03:50 PM
Try DC automotive they will probably have one.
Old 04-22-2017, 05:17 PM
SCadaddle's Avatar
I am more than certain the air guide on my 82SC has the cut out for the voltage regulator 180 degrees opposite the one in the above photo, as the metal vanes on mine were slightly loose so I drilled out the rivets and replaced them to tighten things up. The upper vane wasn't hanging in the breeze as above, and the voltage regulator was oriented on the bottom of the assembly.
Here is a link to the Porsche TSB:
http://bethnrayndogs.com/car_docs/Porsche/porsche/Porsche_Tech/Porsche_TECHNICAL_BOOKS/Tech_Bulletins/Group27_82-02.pdf
Old 04-22-2017, 08:55 PM
Just turn the alternator 180 degrees if you use the 3.2 version of the air guide on your SC with internal regulator. I still have the original alternator with external regulator so I now have an empty notch at the top.
Gustaf
Old 04-22-2017, 11:28 PM
pampadori's Avatar
THanks all. Order placed!
Old 04-24-2017, 08:54 AM
rep rep is offline
Originally Posted by 86 911 Targa View Post
Hope this helps.
Best,
Gerry
Where would I find a parts display like this for a 74?
1974 Carrera
2013 VW Toureg TDI
Old 04-25-2017, 09:38 PM
pampadori's Avatar
I'm not 100% sure because I'm on my work VPN and its slow and often blocks anything that I find interesting....but is it here?: http://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/
I'm going to bookmark it and check it out later. We should have new folks (myself included here) swear on a bible that they have viewed it and dedicated it to memory!
Old 04-26-2017, 05:21 AM
Air Ducting.
Here you go.
Gerry
1986 911 Targa.
Only in L.A.:
Old 04-26-2017, 06:35 AM
