I suspect you are going to want to add a horizontal bar to attach your shoulder harnesses. The guides from Schroth are helpful to understand the geometry.
https://www.schroth.com/en/segments/racing/service/installation-instructions.html
Old 10-19-2020, 04:27 PM
Finished the main body!
Only parts (doors, hood, etc) left!
Photos:
911T 1970 - For racing purposes only
911E 1973 - For racing purposes only (on going)
Old 11-05-2020, 02:42 AM
Painted!
Old 11-09-2020, 02:15 PM
Flojo's Avatar
a bare clean/painted interior is so sexy... and loud
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 11-10-2020, 07:13 AM
AutoBahned
RWebb's Avatar
you like white
and say you like light
so, how light is the car?
Old 11-10-2020, 10:33 AM
you like white
😂 😂 Only noticed now that everything is white around there, pure coincidence!
I didn't measured yet, but I'm assuming it will be 900kg (less than 2000lbs)
Old 11-10-2020, 04:45 PM
Rob T.'s Avatar
Originally Posted by BernardoEsteves View Post
Painted!
Great job Bernardo. Nice car.
I got the same windows in my car.
Especially on a hot day you will feel like you are sitting in a greenhouse without windows, the engine screams and its hot as hell.
But in the end it's worth it
Old 11-11-2020, 03:31 AM
I actually don't know if I should replace the whole window with the normal one with a leather strap or keep this... It is not as perfect as yours is.
Old 11-15-2020, 03:17 PM
Just to update
Clean engine and gearbox in
Old 03-29-2021, 01:20 PM
Does someone have any technical drawing/diagram with measures of a front fuel tank protection?
Like the one on the image below.
Old 01-11-2022, 09:43 AM
Dont have details.However,I think ST parts.com in NZ sell these.Not very expensive.
Old 01-11-2022, 10:37 AM
I have all the means and material to do one (at least, I can produce in series) I'm just lacking the drawing..
I cannot buy outside Europe, otherwise I'll pay more in taxes than the actual value of the part
Old 01-12-2022, 03:41 AM
Hello everyone!
I'm in trouble, what is what I'm doing wrong?
Clearence from sway bar to strut is 0mm... What I'm doing wrong?
Regards,
Old 06-10-2023, 12:10 PM
PCA Member since 1988
That’s because you are using coil-overs. You will have to figure it a way to bend or otherwise provide more clearance, or switch to later style anti sway bars.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 06-10-2023, 10:12 PM
Thank you for your answer, but I see many Rsr with coils and this sway bar.
Might it be the a arms that are with a bigger angle than they should?
Old 06-11-2023, 02:03 AM
917_Langheck's Avatar
What does the gap look like at nominal ride height under static load?
Old 06-11-2023, 07:24 AM
Just to update
Love it!!
Old 06-11-2023, 09:56 AM
Tom '74 911's Avatar
This...
Is your photo of the interference at full droop or when the car and suspension is weighted and sitting on the ground?
If it's at full droop, try setting the car on the ground and rechecking the clearance...
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 06-11-2023, 10:15 AM
Originally Posted by Tom '74 911 View Post
This...
Sitting on the ground looks OK, although I've seen many photos of others and always look like no interference at full droop.
Picture of other following
Old 06-11-2023, 04:15 PM
I agree that coil-overs shouldn't be the reason for interference. I think it's hard to compare pictures car-to-car without all the information... in the photo you just posted that shows plenty of clearance - have the a-arms been modified, are there offset ball joints installed, exactly what type of sway bar is installed etc... all of which could make a difference... also, the a-arms look almost level with the ground and not at full droop.
Can you cheat the sway bar arms closer to the inner fender, away from the strut tube to buy yourself a few more mm's?
I will try to look at the 2 cars I have with RSR struts to see how close the sway bar hardware is to the strut tube... may take a few days, but I'll try to remember to take a look to compare. I seem to remember that it was pretty tight when the suspension is at full droop on my cars, but I don't remember anything physically touching.
I think that if your car is a street or track car that will be used such that the wheels will always be in contact w/the ground and under load, I'd not worry about it too much if there is clearance when loaded. If you use the car for rallying where there are jumps involved etc..., I might be more concerned about the conflict.
Old 06-11-2023, 05:18 PM
