Yeah, the IMS is far worse than the heat ovens that they put on 1977S
Old 05-11-2017, 08:36 PM
So did they give you the old bearing? Does it look like it's ready to explode? ¯\_(ツ)_/¯
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 05-12-2017, 04:26 AM
Diss Member
Quicksilver's Avatar
Look at the LN Engineering fix.
+1
The IMS failure doesn't have a specific mileage when it can rear its ugly head. Set the car up for the long haul. (And, yeah, your mechanic should have explained this to you.)
So which IMS fix did they do? They upgraded the part and the initial upgrade wasn't bullet proof. The later upgrade that is LN's big seller solves the core issue of lubrication by not having an internal seal so the lubrication is basically the supply of engine oil.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 05-12-2017, 02:13 PM
jmpowers's Avatar
I have a IMS guardian I'd sell you, you would just need to get a new drain plug.
-John
1987 Targa -Diamond Blue Metallic
Old 05-12-2017, 02:47 PM
Weekend Mechanic
vulcan300's Avatar
This is what a low mileage early 996 can look like when you pull off the transmission to replace the IMS bearing. I'm sure a lot of this oil is from a leaking RMS, but when I got the bearing out it wasn't shredded but it was also not moving freely anymore.
86 911 Carrera Targa
Old 05-12-2017, 05:41 PM
Weekend Mechanic
vulcan300's Avatar
Afterward with a new RMS and IMS bearing + cover from LN.
Old 05-12-2017, 05:42 PM
What the ?
glewis80SC's Avatar
Change it.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 05-13-2017, 09:26 AM
