Old 60's Porsche Tech
captainlewis's Avatar
1987 carrera cab shock recommendation
I have a 1987 carrera cab 97,000 miles. all other suspension in good working order , bushings, etc. This is a street road touring car for me. The car came from the factory with standard shocks not sport. The shocks are sachs touring and are weak and leaking P/O installed at 35,000. I am looking for the best touring shock. I had a previous 87 coupe that had Bilstein heavy duty front and rear and the car road to stiff (wife with back problems.) I have Michelin a/3s all around stock 16" wheels stock suspension height. I don't care about a second faster in corners I just want the car to handle well and ride comfortably, I have had 7 911s 82 to 87 driven over the last 25 years. I don't need all the B/S about if you want comfort drive a Lexus just some good recommendations from someone who has the same driving style that likes the shocks they put on their car that they think would work for my application. Thanks
1987 911 Cab TRE engine 1952 356A sold ,1960 356B totaled hit by drunk totaled 1979 911 sc Targa sold,1984 911 3.2 Targa sold,1985 911 3.2 Coupe sold 1987 3.2 coupe sold to my son PARTS ENDLESS WORK $$$$$ PREPARING and driving your PORSCHE anywhere with confidence PRICELESS!!
Old 09-10-2017, 09:39 PM
Brew Master
cabmandone's Avatar
I put KYB's on my car and I'm satisfied. I don't put a lot of miles on the car and it does not get tracked. I think from reading your OP that you have already answered your own question. Bilstein heavies are out. Just put the stock Boge back in the car and call it a day.
Old 09-11-2017, 04:35 AM
Koni's.
Richard
87 Targa
20 LS 500
Old 09-11-2017, 06:19 AM
Custom built triple adjustable Penskes with the trick regressive valving option in both compression and rebound.
Matt - 84 Carrera
Old 09-11-2017, 06:25 AM
Thanks Cabmando. I don't see boge shocks or inserts on Pellican parts. Are Sachs for boge inserts equivalent to the original boge shocks. Alignment recently done. Do I need to realign after rear shocks and front inserts.
Old 09-11-2017, 07:11 AM
The car may get slightly higher or lower on the new shocks, but it shouldn't be enough to require a new alignment.
Matt - 84 Carrera
Old 09-11-2017, 09:14 AM
French Import
zippy_gg's Avatar
I bought Bilstein inserts for Boge struts on PP and they are a great fit.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 09-11-2017, 09:19 AM
Under the radar
Trackrash's Avatar
Too bad Bilstein doesn't make an adjustable shock for the torsion bar cars.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-11-2017, 09:55 AM
Custom-valved Bilsteins will make you (and your wife) very happy and they last longer than anything else.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-11-2017, 10:13 AM
Administrator
Dmitry at Pelican Parts's Avatar
As above members have said, Koni is a great shock and has some value to it as well. Also, if you get Koni shocks before 10/31, there is a great rebate that you can take advantage of. Link below:
KONI Shock Absorbers Special Offer - Pelican Parts
Old 09-11-2017, 01:49 PM
Brew Master
cabmandone's Avatar
I didn't have to do any alignment when I replaced mine. I think Sachs is Boge. Your ride height might change a bit but give it some time for the struts to "settle in".
Old 09-11-2017, 03:34 PM
petercory
Steve @ Rennsport was my choice to re-valve the Billsteins on my Turbo-Look Cab; the results were outstanding.
Old 09-12-2017, 05:30 PM
