Good review of one of these systems in UK. Classic Porsche Air Conditioning Test Drive - Ferdinand
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you. |
That's exactly what I did
Stefan '78 911 SC crashed & gone, but not forgotten '77 911 S www.carmania.at |
Wiring
Stefan,
Question, you indicated that you connected the Blue/yellow top of fuse 6 (arrow 1), but wont hooking the wire to the top essentially mean that the connection will bypass the fuse since you are taking the power from the hot side? Thanks, David Quote:
__________________ David Yerkes 1987 911 Targa - GP White |
from the ElectroCooler Install Manual
I too am no expert in electrical wiring, however, based on my understanding these wires do draw power, and because you chose to attach them on the top of the fuse panel, you are drawing unfused power. The downside of this is that if there is a spike in power in this circuit, that the devices connected to the topside of the fuse block will not be protected by the surge as they will get power regardless of that fuse on he circuit having failed. If you or others feel my understanding is incorrect please let me know as I certainly want to have an accurate understanding.
R Gruppe #111 Early S Registry #235 res ipsa loquitur |
It's been a while since my last post on this subject but all I can say is that I can't imagine the car without a proper air conditioning anymore. How could I live without one for so many years (14years to be exact)? I may get older and dont like to drive around at highway speed with wide open windows anymore and I dont like to arrive in soaking wet shirt anymore.
Anyway, here is a modification / additional part I want to present to you: ElectroCooler foot well / blend valve cover This is an improvement of the original 'snorkel' design by Jonny. It was a long way which even included the purchase of a 3D-printer ![]() a lot of hours spent on the computer and a lot of design changes later ![]() I came up with this version: ![]() installed it looks like this (passenger side on the LHD car shown): ![]() inside it futures a dividing wall to separate the cold air coming from the ElectroCooler and the air sucked out of the cabin. ![]() You can download the 3D printing files here ---------------------------------------------------------------------------------------------- Blend valve cover plug My car came to me with a dealer fitted air-conditioning, one of the modification which was done back then was an additional opening in the blend valve top cover for the small side vents in the dash board. ![]() Since this opening is no longer need with an ElectroCooler installed I designed this plug to shut this hole. ![]() You can download the 3D printing file here I also noticed that the cover had some sort of block of half way across the pipe diameter ![]() I removed this ![]() and not surprisingly the airflow was improved
Very elegant design for the vents and thanks for sharing the files! I found those blockages too in the factory parts. I think it was there to balance the air flow with the small hose (that you have deleted). I did exactly the same and removed the blockage.
www.classicretrofit.com |
Austria3 Thank you for the files, awesome to have. What material did you print them from? I used PLA to begin with but I'm thinking it won't survive when the heat is coming out of them, so wondering if I should go PetG or ABS?
Also did you print them with supports? I don't know if my printer would run them without supports, but man are they a pain to clean off!
1971 911T British Racing Green 3.2L 2013 981 Boxster S Aqua Blue/Grey 2014 981 Cayman S Agate Grey/Black enjoyed and passed along: 1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A |
Rennch on YouTube
Did you make these files available? Maybe I can get them printed locally.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
See post 27, he has links there.
Rutager West 1977 911S Targa Chocolate Brown |
Rennch on YouTube
I know tons has been written on this, but I can't find th answer at this point.
I had factory air... With the condenser up front, do I need or want to use this? Will my factory vent manifold work with this system?
Guy Zindel |
My question has been answered
Yes, you block the blend valve 40mm outlets. The 40mm hoses go directly from the outlets on each side of the blower to the metal outlets that feed the side vents.
Who needs AC in a classic Porsche?
Asking for a friend. |
Well there are those that absolutely NEED it ( Florida, Texas, Thailand, Philippines, Hong Kong).
Then there are those that want it, which includes everybody who has ridden in my SC.
since I changed my website and I can not edit such old threads I have to quote myself
and more
and more
