Synchro Joe's Avatar
Good review of one of these systems in UK. Classic Porsche Air Conditioning Test Drive - Ferdinand
Horsepower is how fast you hit a wall.Torque is how far you will take the wall with you.
Old 11-09-2017, 03:33 PM
austria3's Avatar
Originally Posted by Canada Kev View Post
Thanks for the write up. For the hole you don't know what to do about next to your power switch in the console, you could fill it with a USB accessory plug...
Thanks for the tip!
That's exactly what I did
Stefan
'78 911 SC crashed & gone, but not forgotten
'77 911 S
www.carmania.at
Old 05-05-2018, 07:53 AM
Wiring
Stefan,
Question, you indicated that you connected the “Blue/yellow – top of fuse 6 (arrow ‘1’)”, but won’t hooking the wire to the top essentially mean that the connection will bypass the fuse since you are taking the power from the hot side?
Thanks,
Originally Posted by austria3 View Post
3. Electric
Routing all the wires through existing holes in the bodywork took some time but adds to the smooth optic of the whole installation.
View inside the smuggler box. Red arrow points to the stud I used as ground point for the compressor unit. The blue arrows point to the exiting openings from the original AC which I closed.
Grey connector:
Blue/Red – wiper pin 53i (green wire)
Blue/white – switch for rear/front windshield heating - pin 3
Looking through the clock opening in the dashboard to the wiper motor. Red arrow indicates pin i53 (green wire) – wiper at full speed. To test if you have found the right pin/cable, just turn the wiper to full speed, if he doesn’t work, you disconnected the right one.
I used the original mounting bracket, which is still available from Porsche for around 10€, for the on/off push button. I had to enlarge the original hole slightly. I am not sure what to do with the second hole.
Fusebox:
Black/yellow (switched live) – fuse 15 (arrow ‘2’)
Yellow (switched live) – fuse 15 (arrow ‘2’)
Red – fuse 18 (arrow ‘3’) (empty on my car), I also connected the red wire from the fan and the red wire of the on/off button to this fuse
David Yerkes
1987 911 Targa - GP White
Old 07-16-2018, 08:25 PM
austria3's Avatar
from the ElectroCooler Install Manual
...the 3 defeat signals (Blue/Yellow, Blue/Red, Blue/white, all Grey Connector Harness) tell the ECU whether to slow or stop the AC compressor. Wire them to the 12V feed for higher current accessories…... These connections are not mandatory, the ECU can operate without them.
so to my understanding (not an electric expert) there is no power taken and no fuse bypassed.
Stefan
'77 911 S
www.carmania.at
Old 07-17-2018, 01:19 PM
I too am no expert in electrical wiring, however, based on my understanding these wires do draw power, and because you chose to attach them on the top of the fuse panel, you are drawing unfused power. The downside of this is that if there is a spike in power in this circuit, that the devices connected to the topside of the fuse block will not be protected by the surge as they will get power regardless of that fuse on he circuit having failed. If you or others feel my understanding is incorrect please let me know as I certainly want to have an accurate understanding.
David Yerkes
Old 07-17-2018, 01:42 PM
sithot's Avatar
Bring it here. LOL
914World.com - The fastest growing online 914 community!
R Gruppe #111
Early S Registry #235
res ipsa loquitur
Old 07-18-2018, 03:28 PM
austria3's Avatar
It's been a while since my last post on this subject but all I can say is that I can't imagine the car without a proper air conditioning anymore. How could I live without one for so many years (14years to be exact)? I may get older and don’t like to drive around at highway speed with wide open windows anymore and I don’t like to arrive in soaking wet shirt anymore.
Anyway, here is a modification / additional part I want to present to you:
ElectroCooler foot well / blend valve cover
This is an improvement of the original 'snorkel' design by Jonny.
It was a long way which even included the purchase of a 3D-printer
a lot of hours spent on the computer and a lot of design changes later…
… I came up with this version:
installed it looks like this (passenger side on the LHD car shown):
inside it futures a dividing wall to separate the cold air coming from the ElectroCooler and the air sucked out of the cabin.
You can download the 3D printing files here
Blend valve cover plug
My car came to me with a dealer fitted air-conditioning, one of the modification which was done back then was an additional opening in the blend valve top cover for the small side vents in the dash board.
Since this opening is no longer need with an ElectroCooler installed I designed this plug to shut this hole.
You can download the 3D printing file here
I also noticed that the cover had some sort of block of half way across the pipe diameter
I removed this
and not surprisingly the airflow was improved
Stefan
'77 911 S
www.carmania.at
Old 06-10-2019, 06:26 AM
Jonny H's Avatar
I'm with you on that - completely changes the car. I swear it feels bigger inside.
Very elegant design for the vents and thanks for sharing the files!
I found those blockages too in the factory parts. I think it was there to balance the air flow with the small hose (that you have deleted). I did exactly the same and removed the blockage.
www.classicretrofit.com
Old 06-10-2019, 10:59 AM
Austria3 Thank you for the files, awesome to have. What material did you print them from? I used PLA to begin with but I'm thinking it won't survive when the heat is coming out of them, so wondering if I should go PetG or ABS?
Also did you print them with supports? I don't know if my printer would run them without supports, but man are they a pain to clean off!
1971 911T British Racing Green 3.2L
2013 981 Boxster S Aqua Blue/Grey
2014 981 Cayman S Agate Grey/Black
enjoyed and passed along:
1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A
Old 02-06-2020, 11:04 AM
Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
Did you make these files available? Maybe I can get them printed locally.
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 07-20-2020, 04:52 PM
See post 27, he has links there.
Rutager West
Old 07-20-2020, 06:33 PM
Rennch on YouTube
rennch's Avatar
Thank you!
Michael O'Neal -
Old 07-20-2020, 08:49 PM
rsrguy's Avatar
Send a message via ICQ to rsrguy
I know tons has been written on this, but I can't find th answer at this point.
I had factory air... With the condenser up front, do I need or want to use this?
Will my factory vent manifold work with this system?
Guy Zindel
Old 07-20-2020, 09:05 PM
My question has been answered
Old 02-11-2021, 05:38 PM
Yes, you block the blend valve 40mm outlets. The 40mm hoses go directly from the outlets on each side of the blower to the metal outlets that feed the side vents.
Old 02-11-2021, 08:00 PM
Fixer's Avatar
Who needs AC in a classic Porsche?
Asking for a friend.
Old 02-12-2021, 05:39 AM
Jonny H's Avatar
Well there are those that absolutely NEED it ( Florida, Texas, Thailand, Philippines, Hong Kong).
Then there are those that want it, which includes everybody who has ridden in my SC.
Old 02-12-2021, 10:01 AM
austria3's Avatar
since I changed my website and I can not edit such old threads I have to quote myself
Parts arrived:
separately ordered hoses
parts overview:
Stefan
'77 911 S
www.carmania.at
Old 01-16-2025, 06:38 AM
austria3's Avatar
and more
1. Condenser and fan assembly
The left hand head light has to come off to get access to the screw holding the top of the horse shoe bracket
Test fitting the fan assembly, it is tight!
This is the position I had to move the mounting screw
It is a very tight fit, red arrow points to edge of fan/bottom of front spoiler, green arrow points toward front of car.
red arrow point to bracket that holds the impact bumper damper, green arrow points toward front of car.
Everything lined up and connected
This is all you can see from the condenser on my car.
Stefan
'77 911 S
www.carmania.at
Old 01-16-2025, 06:44 AM
austria3's Avatar
and more
2. Routing hoses
I did choose the existing holes from the wind screen washer bottle to pass the hoses from the condenser to the luggage compartment. I had to slightly enlarge the holes to get enough space for the rubber grommet.
This is how I modified a standard rubber grommet
This is the tool I used to crimp the hose connectors. It is usually used to connect steel for reinforced concrete by twisting around some thin wire.
Stefan
'77 911 S
www.carmania.at
Old 01-16-2025, 06:47 AM
