There are like maybe five guys. Peter is among them. I like Johnny's posts also. |
Ok, you made me go look. You can see the dent in the filter screen, more obvious than the pic shows. I'm guessing you are referring to these screws.
They are all tight, none loose. So, the pop off saved me 400 or so bucks and time/labor. When I put this in I smoke tested it with a proper machine buy a gut familiar with this device...it did take some time to get properly seated. http://forums.pelicanparts.com/uploa...1510356252.JPG |
here is the filter....didn't take in the otherhttp://forums.pelicanparts.com/uploa...1510356323.JPG
Ivan |
Air leak sources........
Peter, I have high respect for your accomplishment and your work. Are you aware that there are more than 4 dozens spots (conservative accounting) or locations around the air CIS air box that could leak and cause a lean condition? One intake runner alone has atleast 6 locations to cause leak. Multiply it by 6 and you will have atleast 36. This is excluding the airbox and we are giving you the benefit of the doubt that you have a perfect airbox. A perfect airbox will not prevent the system from not having any leak/s. An air leak in CIS is inevitable whether you like it or not. It is during this uncertainty that you need some sort of insurance to minimize collateral damage. If you do a lot of CIS start ups like after an engine rebuild, a “perfect air box” can not guarantee a backfire-free operation during the very initial ignition of the system. I seldom get this big backfire but it does happen when you least expected it. To say it will never backfire is not true. It may not happen today but it will happen someday unless you are on denial. This is a fact of life. Pop off Valve has its own weaknesses. But some of the problems with the POV could be minimized and corrected with proper and timely maintenance. I have seen and experienced so many strong backfires in the course of my work that common sense must prevail. Not using a POV is like telling a skydiver not to use a back-up parachute because you have been jumping without one for a long long time. You maybe lucky but you can not depend on luck all the time. Not all good and experienced mechanics know or understand CIS very well. My two cents. Tony |
He was kidding. No need to worship him, But I do push his book as often as possible. |
It has been screwed back together with some longer screws I expect which is a common cheap and temporary fix. It will probably will hold smoke when the engine is not running as there is no vibration or heat to distort the crack. (BTW, most 911 airboxes use M4 flat head slotted machine screws. Porsche did swap to crosshead self tap screws on the later airboxes but yours looks like an original ABS type). |
Pop off valve installation.........
Reiver, Are you aware that your POV is incorrectly mounted and installed on your air box? Take a closer look at the POV and it is resting on the plastic ribs instead on the flat base. This a common mistake committed by many DIYers including professional shops. While it is glued in place it is incorrectly mounted by your guy. This is easy to correct if you want to fix it. Tony |
All of them are tight, all the same color (photo light) and the car runs perfectly. How do I know the box does not leak....I have a wide band AFR in place of my clock and monitor AFR all of the time...it is very consistent and only changes a bit with elevation (I live in the foothills 2600 ft but often go above 5k etc.) I am not saying your experience is not valid and they may not work all of the time but this one did once.....and for the investment once is good. |
Top right of your photo does it say PA6 in the stamping? ABS boxes just have a number in a circle. |
Well I was hoping you were right and it was a PA6 but the circle simply has a 2 stamp within.
All of the screws are the same color to include the ones on the drivers side exterior of the airbox (US driver side)...same style and color and extend about a few MM below the attaching points and appear to be self tappers. |
Following up to Pete Z.'s comment, I bought his 82 SC in 2014. Now at 217,000 miles with the airbox he installed. No backfires thus far; no POV.
Sam |
You better pop or your gonna blow!
Also Tony, You're 100% incorrect on your install info. As I stated, I worked for the company that manufactured POV's and I can guarantee you they are suppose to be on top of the ribs. What are you doing? Grinding down the strengthening ribs?? I'd love to see a photo of that. Early air boxes, the ones identified by the slotted screws can accept this, but later boxes, phillips screw, have the cold start distribution spider inside, and my opinion is that the pop off would bottom out on the main chamber and not be as efficient. Who told you to cut the ribs???? (If I'm reading your post properly). |
Thanks...nice to know it is properly in place....the guy that did the top end and put it there has been a P wrench for 40 years....school trained and now an indy. |
| All times are GMT -8. The time now is 02:59 AM. |
