1980 911 SC
Has anyone used an enclosed trailer for long term storage?
Security is not a problem. I live on a dead end road off of a dead end road, and the few neighbors I do have are good ole boys who define the term “neighborhood watch”. It would be out of sight and secured. My question is concerning preservation of the car. The car has been in a dry garage sitting on top of a heavy canvas tarp which lies on top of a plastic vapor barrier. It hasn’t aged in the last 20 years; it’s only gotten better with a little wrenching and caretaking. I don’t want to undo all the work I have done by putting it in a trailer if it’s not going to protect it from rust and aging. I’m thinking I could get a 24 foot trailer that is insulated and put down a vapor barrier on the floor. This would be its home for the next decade or two. The last few years I haven’t been driving it as much as I am spending more time surf fishing with the Jeep. I wouldn’t be driving it more than a dozen times a year, with the occasional 4-5 day stretch when I get a bug up my butt and drive it to work for the entire week. It’s hard to describe the weather here as it seems to be changing everywhere, but in general it gets cold and rainy in the winter. What do you guys think? Would you store your 911 in a trailer? Any feedback would be appreciated.
Life's a Beach |
Brew Master
I would think as long as you have a trailer with good ventilation you should be fine. I'd probably want more roof vents than recommended and see if you could add some sidewall vents for cross ventilation and you should be fine.
disband
if you're not going anywhere for 10 or 20 build a detached 2 car garage where you'd park the trailer. store the kayaks, have a little work bench and a place to hide when the misses is experiencing hot flashes.... tv, radio, internet, fridge, cigar humidifier?? man cave!
the trailer is a cheaper way out for sure. i'd put it on blocks, remove the tires & store simply opening it every couple weeks to air out some. if you are old & fat like me getting in & out of a car in an enclosed trailer can be a pain. you can winch it in & out to be sure, but you can't hide a tireless trailer on the property or escape to it for a coldie & Cuban when the winch is broken your balls. my 2 cents...
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by juanbenae; 11-11-2017 at 05:21 PM.. |
I kept my 1998 C2S in a 24 foot Haulmark for 6 years without issue.
Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98 |
Formerly known as Syzygy
As long as it doesn't leak and you can keep little critters out, I don't see what makes it different than a garage.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
Some people would run a couple of incandescent bulbs to push out the moisture. It seems to work.
Certainly better than leaving it outside. I’d want to make sure no one could hitch it up and drive off with it.
Kurt |
1980 911 SC
Trying to get away from this. I appreciate the input though. No wife to hide from either, LOL. I appreciate all the response. Thanks.
Life's a Beach |
AirBorne!
Moisture, heat and cold can do crazy things to a car in storage. If you put the car in a trailer you HAVE to install desiccant in the trailer and in the car. Dark interiors of trailers are a breading ground for mold and other yucky things. I would also recommend installing a fan in the trailer to keep the air moving around. If you live in an area where the temps exceed 90 degrees during the summer I wouldn't consider a trailer for long term storage. Imagine the humidity levels in the trailer after a summer rain.
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
What about an ocean storage container? Used ones are pretty reasonable, they can be locked and I’m sure it’s pretty easy to add ventilation and lighting if needed.
Euro Spec 73 911S 72T, now ST R Gruppe, S Registry |
Hopefully no one calls CPS on you for abuse.
1980 911 - Metzger 3.6L 2016 Cayman S |
Hey neighbor!! I have used my 24' Haulmark for "storage" for years. During the summer I rotate my cars in and out of the garage, shop, and trailer. Over the winter I keep the same vehicle in it for a 4-5 months. (it may come out for a drive on a nice day when there is no salt on the road). I have not noticed any corrosion/moisture issues. I have a large ceiling vent that stays open year round and never leaks. When it is real hot in the summer I crack the side door to allow extra ventilation. Works for me!
1983 SC Targa, 1973 911 FFR Cobra 1941 Dodge Truck (restomod) 1955 Plymouth Wagon 2dr 1973 Porsche 914 |
I've stored motorcycles, scooters, and race cars in my trailer for 7 or 8 years now. But I bought the trailer new and know it doesn't leak. Walls and ceiling are white vinyl not plywood, floor is sheet vinyl (checkered flag pattern) in one big sheet that was installed over the new wood flooring when the trailer was built. I have two side vents that stay open year round, never open the roof vent because I've had snow blow in. Just bought a Battery Tender solar charger to put in the trailer to keep the trailer batteries charged, but it could just as easily power a fan to circulate air if you're worried about it.
021-1165
Ed '86 911 Coupe (endless 3.6 transplant finally done!) '14 Jeep Grand Cherokee 3.0 Turbodiesel (yes they make one) '97 BMW 528i (the sensible car, bought new) '12 Vintage/Millenium 23' v-nose enclosed trailer |
Reiver
OTOH it is 'tight' and no critters ever and they come with bug proof venting so they do breath. I picked up a new/unused fresh paint (tan) one and had a side door (steel) added by the business and delivered for 4k. Beat the hell out of building a garage and it is solid as in bunker solid.
De Oppresso Liber Strength and Honor 5th Legion |
Standard 20' and 40' sea cans are 8' wide and about 4"-6" narrower for the inside dimension. Your 911 needs to go on a diet if it can't squeeze in there...
Reiver
They make a great garage tho...love mine.
People use them for moving cars all the time. Not a lot of room for opening the doors, though.
Reiver
It would work...I'm going to try it out...if you put a soft mat door side you'd be ok.
I know the smaller size works as my 73 911 that I bought in France was shipped to me in one. I got to crack open the seal and open the door when I picked the car up in Long Beach. Memorable day.
This is what I use excellent product.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiK5YPr48DXAhVINiYKHRfYAksQFgirAjAA&url=https%3A%2F%2Fwww.carbag.com%2Fcarjacket%2F&usg=AOvVaw13dCRBMflSgX3eRv8IBk3T Way cheaper than a trailer |
