Porsche 87 911 suspension help
Question on my front suspension if someone may help, I tried lowering the front but driver side shows 4 threads left and its kinda low already but the passenger side, i needed to go down to 1 thread left when i lowered it for them to match..anyone know why? thanks in advance for the noob question
Old 11-28-2017, 11:10 AM
Jeff NJ's Avatar
Did you drive it around a bit before measuring?
Is the ground perfectly flat and level?
If you are measuring the height from the top of the wheel arch on the body instead of the correct method, which is the difference between the height of center of the wheel and the height of the center of the torsion bar, you can run into this. Handbuilt cars aren't always perfectly symmetrical, so perfect suspension height on each side may have the body slightly lower on one side.
Absent all that, your suspension may be worn. Worn suspension bushings can certainly affect this and a worn torsion bar can too. I replaced all the rubber on my 88 and after the alignment, it certainly felt tighter and more precise, which is understandable with ~30yr old rubber.
1988 930 Venetian Blue
Old 11-28-2017, 11:20 AM
kuba_kuba's Avatar
You may need to reindex the torsion bars if they are off by one (or more) teeth on the splines relative to each other. With the adjustment screw removed you can pull off the cap and put back by a tooth. I think you'd need to have the car in the air for that.
'88 911 Targa
Old 11-28-2017, 12:22 PM
Under the radar
Trackrash's Avatar
You have two issues. First the torsion adjusters don't necessarily have to be even for the torsion bars to be evenly adjusted. There are splines on the end of the torsion bars and the adjusters on the ends are keyed onto them.
The other issue is you have a sway bar that will tend to level out your front suspension. To adjust the ride height correctly, you need to disconnect the sway bar and have an accurate method of making sure the two front wheels are evenly weighted.
Then the alignment will have to be re-adjusted....
Gordon
'71 911 Coupe 3,0L outlawed
well, did you get enough help?
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 11-28-2017, 12:25 PM
thanks guys, ill def check on this with your advices. Thank you
Old 11-28-2017, 05:16 PM
