electrical problem
My heater blower will not shut off even with ignition turned off. I pulled the fuse and still will not shut off unless I disconnect battery. Could it possibly be a stuck relay? Thanks. Greg
Old 12-09-2017, 11:39 AM
What car.......
Greg,
What model year car do you have?
Tony
Old 12-09-2017, 12:30 PM
1986 911
Old 12-10-2017, 07:37 AM
steely's Avatar
first let me say I am not a Porsche heating system guru. (It isn't an intuitive system :-)
This is for the heater blower on the engine?
Do you have Autoheat (round dial on console aft of parking brake and no red levers)?
Which fuse did you pull o/o curiosity?
Would any of this help?
blower-fan-engine-compartment-wont-turn-off
911-3-2-how-does-heating-system-work
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 12-10-2017, 09:30 AM
T77911S's Avatar
you are making think about something I have not thought about in a while. this hurts.
I assume you have the auto heat.
you have 2 fuses. one for L and M and another for hi. you also have a relay for hi.
relays don't usually stick. the hi spd relay is under the passengers foot board. try removing it If the fans are on HI.
if the fans are on low then the main sw in the controls is bad. in the link it would be the top one in the diagram. this is the one that goes bad and runs the fans all the time, although not sure how it runs the fans with the key off. even with the heat on and key off the fans should not run.
sounds like you may have the power to the heat controls wired to something that has power all the time. I would suspect at the fuse block.
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/941050-auto-heat-foot-well-blowers-part-deux.html
is this car new to you?
if not have you recently done some wiring work?
I will have to think about the heat controls some more.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 12-11-2017, 04:14 AM
Hey guys. Thanks for your help. I'm guessing I don't have auto heat because I do have the 2 levers coupled with like a 3 speed rotary switch between the seats. Yesterday I pulled every fuse in the fusebox one at a time and the blower still kept running. Pulled the relays one at a time also and that didn't work either. The switch that controls the blower seems to be operating properly as I can still adjust the speed. If you've got any ideas pass them along. Thanks again. Greg
Old 12-12-2017, 03:30 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
The blower has found some other source of 12V power. I'd look for pinched wires and the like.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 12-12-2017, 04:51 AM
T77911S's Avatar
that IS auto heat.
the switch WILL still control the fan speed if the "main" power sw is bad.
the sw goes bad and is ON all the time. this provides power to ALL fan speeds but the default is low.
take a look at the link I posted. the first drawing has a red wire with "12v" on it. that wire is probably wired to direct power and is not fused.
you can try to lift the carpet behind the center console and disconnect the power although I am not sure if you can get to it without removing the console. there may be a cardboard cover over it.
RACE CAR:: sold
Old 12-12-2017, 05:39 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Heat.
pm sent.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 12-12-2017, 07:44 AM
