I would rather be driving
seal between rear deck and shock tower
Having completely stripped my 72 and replaced lots of sheet metal I am having trouble finding a source for the seal material that is sandwiched between the rear deck and rear shock cross-member.
The archives turn up nothing that I can find. Does anyone have any suggestions? This would be an important part of the cooling system to isolate the heat dump from the heater vent outlets from the engine bay. Thanks
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
911-504-930-00-OEM, Foam block from our host Need two of them. My car has several AC hoses thru that opening and two foam blocks fill what is left.
Gasoline User
Jamie, the p/n comonref lists is correct...here is a thread from years ago about the foam blocks that go in that area.
http://forums.pelicanparts.com/porsche-911-technical-forum/179798-hot-engine-bay.html
Bob V 1974 911 Carrera coupe Grand-Prix-weiß 1977 930 turbo Carrera coupe Hellgelb 2018 Cayenne turbo Schwarz 2019 911 GT3 RS Schwarz |
Awesome. Thanks guys. The pic in the referenced thread just looks like a block of closed cell foam.
This is so helpful. Jamie
