Under the radar
Trackrash's Avatar
Even more
If you want to learn way more than necessary about cam design here it is.
Secrets Of Camshaft Power - Hot Rod Network
Here is what I was talking about when I mentioned the peak lift may not be at the center of the lobe.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-31-2017, 12:08 PM
El Duderino
tirwin's Avatar
Well, you know I always want to know more than necessary. Thanks for posting!
So if symmetry cannot be assumed, is there any way of determing the amount of overlap?
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 12-31-2017, 06:22 PM
Under the radar
Trackrash's Avatar
I would think, in theory at least, that you could still compute the overlap with the opening and closing numbers. What would vary due to asymmetry of the lobe would be the volume or area under the curve, but not the number of degrees of overlap.
Gordon
Old 12-31-2017, 07:02 PM
El Duderino
tirwin's Avatar
I think you’re right.
By the way, the reason I’m asking all this is that I’m working on a way to visualize cam differences. First, I needed to make sure my calculations were correct and I didn’t have any egregious errors. Second, I think my initial concern has been validated. Discrepancies and inconsistent specs are going to make it a challenge. I’ll give it some more thought and keep working on it. When I have something I’ll publish it so people can comment.
For instance, I can make an assumption that there is lobe symmetry. It won’t be perfect but likely good enough.
But that also brings me back to the question that still hasn’t been answered. Are the differences in the two different sets of specs for what is supposedly the same cam important?
Old 01-01-2018, 06:40 PM
Bill Verburg's Avatar
Originally Posted by tirwin View Post
I...
It was answered back is post #2
to reiterate
there are different ways to spec cams
seat to seat in degrees
at 1mm lift
at .05" lift
also the valve lash spec is needed
the simplest way to compare cams is to look at the overlap timing spec which eliminates all the other variables
here's a survey of most factory cams, the one # that summarizes the impact of the cams is the overlap timing #, the higher the racier, the lower the more street/ecological
Bill Verburg
Old 01-02-2018, 05:08 AM
