911SC Gas Fumes
Gas fumes coming from the trunk area of my 911SC. No visible leaks. Car runs great!
What is the best process to determine source of this issue?
Old 01-16-2018, 07:55 AM
Check the wheel well. However, a smoke test is the easiest way to find a leak.
Old 01-16-2018, 08:14 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Gas cap is a common culprit. Can you smell it inside the cabin? Usually you can.
For $15, just replace it.
1981 911SC Targa
Old 01-16-2018, 10:28 AM
wreckah's Avatar
check the fuel connections and lines at the fuel pump, under the front bash panel underneath the car. (between the front wheels)
before: '69 Porsche 911T bahama yellow
now: 1981 911 SC Targa winered
Old 01-16-2018, 10:51 AM
the charcoal canister may have been deleted or it could be clogged. or a cracked expansion tank in the wheelwell.
Old 01-16-2018, 11:45 AM
Gordo2's Avatar
Fuel Smell
This may be helpful:
http://forums.pelicanparts.com/porsche-911-technical-forum/938914-fuel-smell-odor-replaced-gas-tank-vent-lines-hose-83sc.html
Good luck,
Gordo
Don "Gordo" Gordon
'83 911SC Targa
Old 01-16-2018, 07:38 PM
Earthling
Brian Cameron's Avatar
Also consider replacing the seal on the tank level gauge. I had fuel smell in the trunk that went away after I did that.
Good idea to check all the fuel lines in the frunk while you’re at it.
1996 Porsche 993 C4. His
1979 Porsche 911SC - sold... and now BACK again! Hers
2021 Volvo V60 (foul weather drive)
2024 Volvo XC60 (spousemobile)
Old 01-16-2018, 11:32 PM
Hi all....even though this issue has been beat it is time for a new twist on this old topic. In the process of trying to track down pressure building up in the gas tank I resolved to test every component in the vent process to the point of breaking open the cannister (which was easy and looked good). My last test found the problem and an unbelievable one it was. Under the fuse box in the frunk is a little line that goes to a pipe behind the gas pedal and then through the tunnel to the charcoal cannister in the rear passenger side. This pipe was clogged with some of the nastiest stuff I have ever seen in a pipe and it was very difficult to find because I had to cut the pipe to see what was going. Since this line is carrying lots of gas vapor it must have had bad gas, varnish, and gas additives accumulating into a solid mass throughout the line. It wasnt rust. It looked more like crystallized carbon, and gasoline products. This condition cause pressure to build up in the gas tank resulting in a loud whoosh when the cap was released. BE CAREFUL....determine if your tank is being overpressured by a blocked line or a vacuum is causing an inhale to the tank. Each has a different cause. If your tank is being pressurized I would bet money on the small vent tube to the cannister. You cant just replace the hose because the line may be completely blocke and it is not east to tell. Best way I found was to see if the air passes through the hose front to back. I attached some fun pictures but the solution is the hard one. Replace the line all the way back. I havent seen this problem described in detail before so have fun because I now have to replace the line to keep it stock.
Old 06-02-2020, 04:47 PM
Good to know, hopefully you got your problems solved.
Old 06-02-2020, 05:12 PM
Any chance 100+ psi compressed air would blow it out? Rob
Old 06-02-2020, 05:38 PM
creaturecat's Avatar
i used air. it worked.
some nasty looking stuff (as described) puked out of it.
remove line at charcoal canister beforehand.
Old 06-03-2020, 07:07 AM
Tags
911sc , fix , gas fumes
