1971 911T SSI exhaust with Carrera trailing arms
Having rubbing issues with passenger side shock rubbing against header. What's the best fix? I really do not want to bend lip of header. I was also thinking of cutting off 1 inch on lower shock mount of trailing arm to change angle.Any other suggestions?
Air Cooled
Do you have any pictures?
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat" - - '99 Honda VFR800Fi, '98 Honda SuperHawk '88 Honda Hawk GT, '77 Honda CB750K Cafe '69 Honda CL350 |
The 911 SLANT is not right....
76' 911s Signature Edition |
Carrera trailing arm mod
I just found the link. Took me about an hour to find. Quoting Bill V. This mod has to be done to 69-71 cars. 25mm which is about a 1in. Should be cut off to give shock the right angle.
Carrera Mod
Here is a pic. Of 25mm cut off arm.
Air Cooled
Oh wow, interesting. I haven't seen that mod before, but it makes sense now that I can see what you mean.
Are we modifying both left and right arms so the damping rate remains equal left to right? Changing the angle changes the rate and that is fine as long as both sides are changed equally.
Yes
Well documented problem when using aluminum arms on the 69-71 cars. Take a gander at https://members.rennlist.com/911pcars/AlloyContrlArms.htm
if you haven't done so already. Todd
1989 911 Targa |
I would rather be driving
The rear shock cross-member mount has a different angle than 72+ cars. It is well documented the rubbing on the early cars as others have posted.
On my old 71 I had to mill the trailing arm and "massage" the lip on the SSIs to clear. I just folded it down with a hammer. Easy.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Here's a shot of it rubbing. I will post outcome when done. I only have 2 inches from CV boot.
Here's my measurement. Shock will clear SSI heat exchanger and CV boot. Keep in mind that when shock rises the clearance will be greater. We'll post more pics after cut is made.
Sorry that pics are sideways. Don't know how to turn them .
Air Cooled
It's ok, my neck turns! haha
Carrera 3.2 Targa
great write-up!
I would like to use aluminum trailing arms also on my 1971 911T. Were you able to use the same 1/2 shaft, hub, bearing set etc. as was originally on your 911T. My car uses a 901 transmission and also has SSI headers.
Thanks in advance, Fred
1971 911T 2016 Boxster 1988 Vanagon (crashed) 1985 Carrera Targa (Sold) 1970 VW Beetle |
No, running 915 with 87 Carrera trailing arms and axles.
Here is the modification done. Clears heat exchanger and axle boot with no problems. I did have to use shorter bolt on lower shock mount.
Canyon Runner
Where did you get the machining done ? I'm in need of the same Mod.
I did it myself. It was easy. Using a electric saw with metal cutting blade.
