How does the idle adjustment screw work??
Hey guys, interesting questions... or so I think. I have my car running with MS2 and EDIS 6 and its silky smooth. The problem is that it can't hold idle because it's too low.
I figure the idle adjustment screw works by opening a valve and letting extra air in. My question is which nipple on the throttle body does this air come from? Any of them? Does it simply draw air past the butterfly in the throttle body and not from the external nipples?
- The reason I ask is that I have all the vacuum ports capped off except the one all the way on the back. I'm using that for the Megasquirt MAP sensor. Do I need to uncap any of them or relocate the MAP vacuum line? I have not messed with the screw for fear of messing up the MAP signal to the MS2.
Car is a 1980 911SC.
Old 02-02-2018, 12:51 PM
Administrator
Dmitry at Pelican Parts's Avatar
Hello - I was able to find 2 earlier threads where the idle adjustment is discussed - hope this helps you a bit.
http://forums.pelicanparts.com/porsche-911-technical-forum/418230-idle-adjustment-questions.html
http://forums.pelicanparts.com/porsche-911-technical-forum/740130-idle-adjustment-screw-what-tool.html
Old 02-02-2018, 01:12 PM
Originally Posted by Dmitry at Pelican Parts View Post
Unfortunately, neither of those help with my situation.
Old 02-02-2018, 01:30 PM
proporsche's Avatar
to help you would be the best if you take some picture what exactly you have capped or not.
BTW How is you distributor timing?When was the last time you have checked it?
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-02-2018, 01:40 PM
Ivan
There is no distributor, there is no CIS. Everything is capped except for the rear most vacuum nipple. That is being used for MS2.
Old 02-02-2018, 01:53 PM
proporsche's Avatar
ok never mind but picture will help;-)
ivan
Old 02-02-2018, 01:59 PM
The idle uses a tunnel between a port above the butterfly and one below the butterfly, with the idle screw as a valve. So, the air is contained within the throttle body, no exterior ports needed.
IIRC the 1980 throttle body has it internal to the housing, while the later 81-83 throttle body has it as a kind of tube going out of the housing.
http://forums.pelicanparts.com/porsche-911-technical-forum/113610-vacuum-source-1980-sc.html
that thread shows the hidden internal tunnel and the idle screw in the first picture.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 02-02-2018, 02:18 PM
Thank you, that was the answer I was looking for!
Old 02-02-2018, 02:27 PM
You can also adjust the base throttle blade position as well if the idle screw does not get you where you need to be:
-Jayson
1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85)
IG: Signature_911
Old 02-02-2018, 02:33 PM
