-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Valve adjustment (http://forums.pelicanparts.com/showthread.php?t=987730)
Nick Triesch 02-15-2018 09:43 AM
Valve adjustment
Hello, my name is nick and I adjust number 6 intake valve by feel. There, I said it!
jlex 02-15-2018 10:05 AM
Ha... Sounds like an introduction at an AA meeting. :)
Good for you. May be just as accurate as wedging a feeler gauge in there that you can't see.
proporsche 02-15-2018 10:25 AM
Hi Nick i`m Ivan and i am not.........anyway i do not use feeler gauges when i adjust valves. Been doing it by feel since the 1980`s...congrats
Ivan
Flat6pac 02-15-2018 10:27 AM
Well, here is something even better for the thinker..
The thread pitch is 1mm, think about it.
Bruce
Nick Triesch 02-15-2018 12:54 PM
One of the best air-cooled mechanics in town told me that some of the valves must be done by feel. Like number 6.
proporsche 02-15-2018 01:25 PM
Nick+10000http://forums.pelicanparts.com/support/smileys/wat6.gif
i wonder who told you that;-)
Ivan
Trakrat 02-15-2018 01:42 PM
#6 intake says "bro... you really hit my right in the feels"... "you really know how to feel your way around my intake"... "I never knew you had feelings for me"... "did it feel as good for you as it did for me"....
don't forget to tip your waiter!
brighton911 02-15-2018 02:41 PM
It's true, after you have done enough of them, you can get pretty close just by feel. That being said, I still use a feeler gauge when setting but for checking, by feel.
john walker's workshop 02-15-2018 04:12 PM
Still using a feeler gauge. #6 too.
DWeg1998 02-15-2018 04:31 PM
I’ve only done two valve adjusts and still could tell by feel if I got it right or not as a final check.
manbridge 74 02-15-2018 05:13 PM
I always check with feeler after doing by feel. Usually dead on.
Pro tip: when holding tool sideways on exhaust valve it should just be tight enough to keep tool from falling/moving under its own weight.
john walker's workshop 02-15-2018 06:58 PM
If you can slip it in and out easily without giving it a couple of light twists, it's still a tad on the loose side.
Bill Douglas 02-15-2018 07:09 PM
Well done.
I check them all by feel but use the gauge on the rare occasions I have to adjust one.
Canada Kev 02-15-2018 07:15 PM
I use a feeler on all, even #6 intake. It's not that tough to get to. But I have smallish hands, so that may help.
whiz05403 02-15-2018 07:28 PM
Sounds like a couple ex girlfriends I had!
Tippy 02-15-2018 08:04 PM
Bruce
Fingertight, then 1/10turn CCW
proporsche 02-15-2018 10:57 PM
tippy+1http://forums.pelicanparts.com/support/smileys/wat6.gif
pampadori 02-16-2018 05:48 AM
amateurs...
I do it by hand AND sound....while the engine is running! it hurts a little but is the most bestest.
Peter Zimmermann 02-16-2018 03:53 PM
Ex-act-a-mundo. And yes, a feeler gauge is necessary. You don't have to "see" the gauge, you only have to "feel" it. You wiggle the rocker to break the oil lock, then you adjust it. When it's snug you pull out the gauge, but always make sure you can re-insert it. If you can't put it back in, with a wiggle if necessary, start over.
ALWAYS be sure your gauge is in good condition, and has no scratches or dents. If it isn't dead smooth, break off a chunk, dress the edge of the new metal on your bench grinder, and go at it. If you use the type of gauge that has the short section held with screws and a small plate, replace the gauge piece.
At my shop we used a long piece of shim stock, about 8-10", held in a handle. That allowed us to break off a piece that was used up, pull the stock through the holder, and then dress the edge where the break was. Much easier to use. 1-6-2-4-3-5.
john walker's workshop 02-16-2018 05:07 PM
Island911, over in PARF made a bunch of these years ago. Awesome.
http://forums.pelicanparts.com/uploa...1518833231.JPG
