-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Classic Retrofit: Six phase high output alternator. (http://forums.pelicanparts.com/showthread.php?t=990208)
Jonny H 04-04-2018 01:32 PM
We are looking at some time in May for production units.
SoCalSK8r 04-12-2018 09:46 AM
Oh I can't wait... my car is once again having alternator problems so I'm holding out for this baby.... replacing the alternator was a pain the back...literally, so I'm only looking forward to doing this once more...
Can you provide any estimates on cost?
Jonny H 05-22-2018 11:51 AM
<iframe width="1280" height="720" src="https://www.youtube.com/embed/WqnYbu8slU8" frameborder="0" allow="autoplay; encrypted-media" allowfullscreen></iframe>
Tremelune 05-25-2018 11:24 AM
Pretty sweet. Is the voltage regulator adjustable at all? It'd be nice to clear 14v at the battery.
Jonny H 05-25-2018 11:37 AM
It is but you're seeing my in dash meter which is 0.3v below the battery voltage. You'll always get some voltage sag on high continuous loads. Drop a feather on the throttle and you're above 14V.
Most 911's struggle to hold 12v with all the toys switched on at idle :)
Harpo 07-07-2018 04:10 PM
Are these available to purchase yet? What about my external regulator? Will you offer a new alternator wiring harness that will enable me to bypass my external regulator?
rwest 07-07-2018 05:50 PM
Looks like some stock is available.
Upgraded Porsche 911 Alternator
RSTarga 07-07-2018 06:37 PM
Unless this has something special all you need is to tape off the connection at the external regulator and connect your existing wiring. I just wonder if the existing wires need to be higher capacity.
timmy2 07-07-2018 09:10 PM
The website (and first post of this thread) recommends to change out to #4 AWG cable from alternator to starter. Also the ground to the case. Especially if you are installing their electric A/C unit.
I’ve built a couple of harnesses upgraded to that size cable for this alternator.
He (Johnny) sent one customer a replacement cable with the new alternator, but no provision to add the second wire (from 14 pin connector) to the crimped B+ connector as original. Could run it on a second lug, I cut off the supplied connector and crimped in the second red wire as per original.
Basically you need to remove the entire engine harness and strip out the original red cable and replace it with the larger gauge one to get it through the engine tin grommet to the starter area. (If you want it to look good)
timmy2 07-07-2018 09:23 PM
This is one of them, 3.0 EFI and stand alone ignition going in a ‘71 so just a really basic harness. You can see the routing of the new larger cable.
http://forums.pelicanparts.com/uploa...1531027325.jpg
Jonny H 09-12-2018 01:49 AM
Finally got round to writing the install manual. It also has technical details and performance figures.
PDF on this page:
Dennis, nice harness! I agree that making a new harness is the correct way to go and a obvious choice if the engine is out.
When the engine is in the car, it is a bit more of a challenge. Most installers elect to leave the original battery+ wire in place but disconnected(heat shrinked and safe). The 25mm2 cable we provide can then be run separately. On my own car (an SC), I made an extra hole in the engine tin (with rubber grommet) and the grey piece of shroud above the oil cooler. This allowed me to feed the wire into the shroud and route through to the alternator. Next time the engine is out I may be giving you a call!
uwanna 09-12-2018 05:45 AM
PDF on this page:
Anything upcoming for the '89 and up 3.6 motors for us transplant guys?
timmy2 09-12-2018 07:52 AM
I’m always up for some horse trading. :)
IIRC you would need a ‘78 CIS harness ?
PDF on this page:
Jonny H 09-12-2018 09:39 AM
Oh yeah, in development! Expecting first engineering samples in a few weeks.
uwanna 09-12-2018 10:30 AM
Johnny,
Would the upgraded alternator eliminate the need for the higher speed
alternator pulley/bearing and make the single pulley retrofit more appropriate?
Jonny H 09-12-2018 01:31 PM
Originally Posted by uwanna (Post 10179054)
Johnny,
Almost certainly. Our current 150A unit puts out 75A at idle. We are aiming a bit higher for the 964/993.
(The normal 115A 964/993 unit only manages 40A at idle)
power_up 09-13-2018 04:24 AM
Very looking forward to 964 items.
ClickClickBoom 01-10-2019 06:33 AM
3.2-3.3 Serpentine fan belt conversion 1984-89 [9110-03] - $519.00 : Clewett Engineering, The complete solution for ignition & fuel injection
Jonny042 02-14-2019 07:09 AM
I'm in the middle of a ground-up rebuild and would like to (if not actually purchase and install) prepare the car for eventual installation of the 150A alternator and electric AC and future possibilities of heat.
Is the main cable through the tunnel of the car able to sustain the sort of amperage these accessories will draw? Or is it already large enough due to starter demand?
(Edit-) Can't say it enough, thanks to Classic Retrofit for engineering and manufacturing and supporting these quality upgrades!
Jonny H 02-14-2019 08:14 AM
As you guessed, the main starter cable from the battery is capable of handling the load. The wire from the starter to the alternator is not. We supply the 150A alternator with a heavy duty cable set that replaces this wire and the ground strap.
See the alternator install manual on this page:
https://www.classicretrofit.com/pages/manuals-and-software
anglophone1 02-14-2019 01:46 PM
Have one of these on the way!
Jonny042 02-28-2019 07:02 AM
Apologies if I missed it, but is there any weight loss benefit to the modern 6 phase design of the Classic Retrofit unit? Stock alt. for the SC is not particularly light and it seems the fan shrouds are prone to cracking from the load.
Tom Elder 03-07-2019 08:52 AM
CDN_Jonny, UK_Jonny’s alternator looks like a nice piece, weight for a 90 amp Paris – Rhone alternator is 5.88kg, Classic Retrofit 150 amp alternator is 5.16kg. Impressive power to weight ratio. Thanks UK_Jonny
Jonny H 03-07-2019 10:29 AM
Thanks Tom, I guess you had it on the scales!
Regarding fan housings, the later fan housings are the most fragile because Porsche had to remove more material to squeeze in the longer 75A and 90A alternators.
For our 150A unit, the mounting points are the same as the shortest early units. This means that it is a direct fit to the stronger/thicker early housings. Of course, you can still use our alternator with later housings by fitting our spacer/adapter rings.
Jonny042 03-07-2019 05:03 PM
Thanks, Tom!
stephen1070 03-24-2019 07:53 PM
1989 3.2 installation
Good evening - need help from the Pelican collective.
I purchased this upgraded alternator to install in a stock 1989 3.2 Carerra.
The black ground connection to the case was straightforward and self explanatory.
However I need help with the 40" red cable connection to the starter.
I read the instructions.. it says some cars need a hole in the engine tin - how do I know if I need a hole? - I'm ready with a drill and my car is on stands (aka ramp) but can someone tell me if I need to be drilled? if so how large?
""Replace the engine GND strap with the heavy duty black cable. Replace the main alternator cable with the heavy duty red cable. This needs to be routed to the starter solenoid. Easier to do this on a ramp. Some cars may need a hole drilling in the engine tin above the oil cooler but be VERY carefully. The engine tin in this area can often be removed with the engine in place.""
https://cdn.shopify.com/s/files/1/0049/4734/5506/files/150a-alternator-install-manual.pdf?15241926203698886546
Also from reading the thread above it appears that the existing connection needs to be 'insulated' (shrink wrapped) after this new connection is made. Can someone confirm this.
All advice would be welcome - thank you.
Regards,
spuggy 03-25-2019 08:58 AM
I'm half-way through this, and got side-tracked into something else while i've got access...
I'd suggest to trace your harness and look at your tin. My 930 tin had a large, shaped hard-rubber grommet on the the top edge of the horizontal tin that all the wires to the starter solenoid/battery post from the engine bay passed through originally.
I intend to enlarge the hole in the grommet to enable the replacement cable and its friends to fit as the originals did. Just haven't found the best way to do this yet.
Not clear what "connection" you're talking about insulating?
If you're asking about re-wrapping the harness, trouble with shrink wrapping it is that there's a few extra wires that leave/join the harness back there, and kind of impractical to do this without removing the motor harness from the car.
Which you could do I guess - I wasn't planning to. It was suggested to me that Wurth-branded insulating tape is very close to what the factory used and doesn't ooze glue or unravel like cheap electrical tape certainly will...
I think possibly the most time-consuming part is getting the old cable out :)
Tremelune 03-25-2019 07:01 PM
Tesa tape (fuzzy OEM harness tape): https://smile.amazon.com/gp/product/B00EH6IZ6Y/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
Cold shrink tape (non-adhesive, but sticks to itself): https://smile.amazon.com/gp/product/B00O7S1B4A/ref=oh_aui_search_asin_title?ie=UTF8&psc=1
Jonny H 03-25-2019 11:36 PM
As spuggy says, the original red charging wire passes through a rubber block that clips to to the engine tin. Ideally, you would pull the original wire out, enlarge the hole and thread the new one through. That would be easy with the engine out.
With the engine in, it is easier to route the new wire via a different path through a new hole in the tin. In this case the ends of the disconnected original wire need insulating to prevent them shorting something out. Fold the ends back and heatshrink or tape.
ClickClickBoom 03-26-2019 09:28 AM
So, if one was going to replace the fan housing on a 3.2 due to corrosion, and wanting to add a modern alternator like this, which "early" fan housing would be correct?
Jonny H 03-26-2019 02:28 PM
It depends what you mean by correct as they can all be made to work. Earlier cars than the 3.2 are tapped for the coil mount which you won’t need. Probably the easiest to source would be the mid year, requiring a single 10mm spacer. Best to avoid the smaller early SC fan.
ClickClickBoom 03-26-2019 02:47 PM
Thanks!
A buddy and myself are looking into modeling the fan shroud and possibly CNCing a replacement out of 6061 or something similar, with the fan as a possibility. Since the only option is Vertex at a very handsome price, there might be a section of the market for a high quality CNC part, since the OEM parts are no longer available.
I watched the Vertex price rise from $395.00 to almost $800.00, this indicates that they think they have cornered the market and are taking full advantage of the cornering of the market.
What say ye?
toddetch 01-09-2021 11:31 AM
Hi Pelicans,
I am now working on this and have questions similar to Stephen's above. I guess I'm nervous about getting this right, especially when it might (probably) mean cutting a hole in the engine tin....
The engine is in, and given all the wires wrapped up together, it feels like it is going to be better to find a new route for the cable from the solenoid to the alternator. Going from below, I found a spot that seems to have, well not a grommet, but a kind of rubber sheath or something which I could push the cable under and up into the engine bay. Here is the view from below:
http://forums.pelicanparts.com/uploa...1610223022.jpg
Here you can see where it is sitting on top of the tin - this is on the right side of the engine, underneath the airbox:
http://forums.pelicanparts.com/uploa...1610223502.jpg
First question: is this an okay place to route the cable?
Assuming the answer to that question is yes, for the second question I'm wondering where the best place to cut a hole in the tin is? Maybe where either the yellow or green arrows are pointing below?
http://forums.pelicanparts.com/uploa...1610223684.jpg
Third question: what is the best way to cut this hole in the tin? The flat part of the cable terminal is about a 1/2 inch wide and the cable is about 3/8 inch thick.
Last question: the instructions say that if I'm not removing the original red cable, to fold back the ends and wrap them. Makes sense. I can easily do that with the end at the solenoid. However, the end at the alternator has a second, smaller red cable that shares the terminal with the larger cable from the solenoid. Should I just connect that end or should I snip the smaller cable, get a new terminal for that cable, and wrap the alternator end of the larger cable? Pic below.
http://forums.pelicanparts.com/uploa...1610223962.jpg
toddetch 01-09-2021 02:34 PM
Actually, I think I figured it out...what I was thinking was the engine "tin" is actually the engine shroud (the orange cover). I think the tin referenced in the instructions is the engine cover, part 4 in the diagram below. It does look like I can remove it with the engine in place with four bolts. Will try that tomorrow.
http://forums.pelicanparts.com/uploa...1610235248.jpg
Matt S 03-19-2021 03:39 PM
I have the same question. I think the smaller cable runs to the external voltage regulator which, if you haven't already, you'll be decommissioning during this install. The Porsche Tech Bulletin leaves this positive cable and disconnects the thin negative (black) cable instead.
Can anyone confirm that the small red cable runs to the external voltage regulator, and that it can be disconnected and insulated when installing a Classic Retrofit Alternator?
timmy2 03-19-2021 09:39 PM
Small red wire runs directly to pin 14 of the 14 pin connector and supplies power to the top 2 fuses of the 3 fuses on the rear panel.
Cut it from the original fat red at original terminal and put a terminal on it to fit along with the positive terminal with the new cable.
Black DF wire is the only one that gets tied back regarding the now internal VR.
Jonny H 03-20-2021 12:01 AM
^ Confirmed. Thanks Dennis. Yes, the smaller red wires that are crimped with the original fat red wire need separating and connecting to B+ on the new alternator.
@toddetch, yes engine tin, refers to the part you have arrowed red in the drawing. Behind that part is the grey coloured part of the shroud that fits above the oil cooler. On my SC, I drilled a hole through the tin AND the grey part. Use a rubber grommet where the cable goes through the tin.
This brings the cable through into the area above the oil cooler. If you look inside the shroud, there is a another piece of tin which is horizontal, kind of like a shelf - the cable will come through above there then its straight forward to get to the back of the alternator.
Cad.Guy 10-03-2022 03:39 PM
Johnny -
Question for you about your alternator.
Is it normal for the voltage to fluctuate between starts ?
On initial start after install I got 14.5 volts. Next day it was 13.9, then 13.4, then it was back to 14.1.
Everything is tight, well grounded and wired and routed correctly.
Just seems strange for such fluctuation.
The only load is the stock fuel pump, ignition and running lights with all bulbs replaced with LEDs.
1979 911sc stock.
timmy2 10-03-2022 08:00 PM
Charge voltage is dependent on battery state of charge.
ant7 10-04-2022 01:06 AM
Its good that there are folk out there looking into the issue of relacement alternators for the 911, however; my thoughts on fitting an alternator with higher output are obviously on a diffrent path to most who have posted here ie; the alternator fitted to the later 3.2 era cars is well up to the job of supplying the necessary current needed for a car in standard form, even with extra's like upgraded sound systems [within reason] so I guess the only folk who would need to look seriously at a higher output alternator as described by the OP would be those who wish to fit more higher current hungry systems and devices than standard.
Remember too; the more load you put on the alternator, the more stress you are putting on the belt driving it, and also you will be using more power from the engine that could be used in more fun ways!
But as has been said; each to their own, and I wish the OP success with their products. :)
