-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   Classic Retrofit: Six phase high output alternator. (http://forums.pelicanparts.com/showthread.php?t=990208)
Tremelune 10-04-2022 10:15 AM
The stock alternator is fine, but any alternator running consistently at 90% output vs 50% output will fail more quickly. The modern 6-phase is more efficient, so even the same load on the engine results in more power to the electronics. In addition, 1hp is something like 750W...It's not an AC compressor we're talking about—you'll never feel a power drop even with your 2kW subwoofer booming.
Really, the big thing is that factory alternators (sometimes even rebuilds unless you "know a guy who rebuilds these") are already in the $500-1,000 range, so why bother...?
Jonny H 10-04-2022 12:30 PM
Time passes and technology improves. Nowadays it is quite normal for a small hatchback (e.g. VW Golf) to have a 180A alternator and SUVs are regularly seen with 220A+ units. Even tiny cars like the Toyota Aygo have 100A units.
Originally Posted by ant7 (Post 11813355)
Remember too; the more load you put on the alternator, the more stress you are putting on the belt driving it, and also you will be using more power from the engine..
An alternator only provides the juice to cover the electrical load at any one time. A larger alternator does not load the engine anymore than a standard unit for the equivalent power output. In fact, our units, being super efficient at turning rotary motion into power, most likely load the engine and the belt LESS.
the alternator fitted to the later 3.2 era cars is well up to the job of supplying the necessary current needed for a car in standard form
In the USA, the 3.2 cars had the largest battery I have ever seen in a sports car - 100Ah. European cars generally had the shorter 75A battery. Maybe this was only on the AC equipped cars but it's a sure sign that the alternator was not large enough for the vehicle.
When you have a decent modern alternator, you can downsize your battery considerably. I have run the same Odyssey PC925 for 5 years now. It's only 28Ah and it always starts the car - I don't even use a battery tender.
ant7 10-05-2022 06:54 AM
I aprreciate that more efficient alternators have been produced since these cars were first in production, and if you can fit one without too much bother or alterations then I am all for that. My original point was aimed at folk who would fit a larger output alternator to supply add-ons that take a lot more current than the standard fitments; ie some were talking about fitting electric heater systems so they could do away with the heat exchangers, my point on that one is why ? you have free heat with your exchangers, why would you do away with them and fit an electric heater system that would put a lot more load on the alternator, thus more load on the belt and hence use more power from the engine!
Jonny H 10-05-2022 11:51 AM
^ Well the reason Singer asked us to design electric heat for the DLS was to save the weight of the heat exchangers and the associated pipe work. The heat uses 1600W, the AC uses 1000W, so combined this is around 3.5 HP.
Of course, we load balance the power if both are on so the reality is about 3 HP max. That’s about half the HP that the old York AC compressors used.
ant7 10-06-2022 12:40 AM
1600W = approx 133 amps from a 12v supply just for the heater :eek: with the heater and AC combined; your looking at over 200 amp, plus everything else the car needs to just run, is the weight saving really justified ?
Jonny H 10-06-2022 01:34 PM
Correct. IIRC, it saved about 20kg but it also solved a bunch of packaging, operational and optics problems. DLS has a 340A alternator. Ruf SCR/CTR alternator is even larger!
Jonny042 10-06-2022 05:09 PM
Is there really much (or any) need to run both AC and heat simultaneously?
I for one would think a small electric heat option for the Electrocooler would be well received but I guess you'd need to limit it to 1000W - in your experience would that be enough for the occasional de-mist or to take the chill off on those 5 degree mornings in the fall?
Very few of us driving these cars when the temps are below freezing and there's any possibility of snow (and road salt!)
ant7 10-07-2022 12:35 AM
Developing more efficient ways of producing electricity is good, especially when we are dealing with transport, ie; more efficient alternators take less energy to turn them for the same energy output as an older design, hence lower fuel use and less emisions etc and the more useable HP you keep under your right foot.
I get that and am fully suportive, however; what I struggle with is the fact that these savings are being made only to provide the extra energy needed for other power hungry devices which I struggle to justify, but I say again, what ever floats your boat, horses for courses etc :)
Jonny042 10-07-2022 04:27 AM
There are many compelling reasons to install electric AC in a 911. Cleaner engine compartment, no hoses running back and forth under the car, lighter weight, better packaging, better weight distribution.
Adding a small, light heating element to the blower assembly (I assume this is how this is being accomplished) would allow you to run headers (again with packaging and weight advantages) without heat which for many is a big deal.
ant7 10-07-2022 05:34 AM
mysocal911 10-07-2022 05:57 AM
Really? Most all Porsche shops consider this modification as laughable and a way to ruin & devalue your Porsche.
Nditiz1 10-07-2022 06:13 AM
I fail to understand how adding a luxury, that is totally reversible and made no additional holes or modifications to the stock car, can ruin/devalue the Porsche, especially if it never came from the factory with A/C. I'm not onboard with the electric heating aspect, as heat is free, but fully support the A/C. Survivor cars/all original cars would only benefit from an AC system. Also, if these cars are sooooo valuable that adding a luxury devalues them...why drive them at all...adding miles devalues them.
Sorry to derail the OP's thread subject.
mysocal911 10-07-2022 06:27 AM
Your minority opinion! There're exceptions though, i.e. when you convert your Porsche to electric and have a 400V battery supply, a 400V compressor is perfect and efficient
& requiring about 1/30 of a 12V system current. Since the typical AC engine power consumption is about 3 HP (2250 watts), the typical 12V AC system requires more than
150 amps from the alternator alone!
Jonny H 10-07-2022 11:35 AM
Clearly we are not talking to the same shops! 😂.
Below is a poll of the 30 best Porsche shops IN THE WORLD, we supply 22 of them with our electric AC kits. Several OPCs have fitted our kits as well. Sorry, I know we should try harder…
https://www.supercars.net/blog/best-restomod-porsche-restoration-shops/
Ruin, devalue? Not sure I follow. Our AC kit requires no modifications to the 911 body at all, not a single hole drilled or wire cut.
mysocal911 10-07-2022 12:55 PM
Makes for a good "labor sell" when shop business is slow, right?
proporsche 10-07-2022 01:08 PM
Clearly we are not talking to the same shops! ��.
Johny..do not even try dude, to reason with him ignore is the best..
Ivan
mepstein 10-08-2022 06:49 AM
Many high end Porsche shops are installing electric a/c. I believe PMS is a big purchaser of the systems. If you don't like electric ac, fine but don't make **** up.
mysocal911 10-08-2022 09:44 AM
Really? I'm involved with many Porsche shops here in SoCal , and most/all indicate that they have NO interest in an after-market installation,
and ALL the on-going headaches once the install is completed. You're obviously not knowledgeable about operating a business,
and much less about what's required to be a successful Porsche independent long term (10-25 yrs).
Jonny H 10-08-2022 12:31 PM
Originally Posted by mysocal911 (Post 11816938)
Really? I'm involved with many Porsche shops here in SoCal.
In what capacity are you involved and what is your business name?
proporsche 10-08-2022 01:10 PM
[QUOTE=mysocal911;11816938]Really? I'm involved with many Porsche shops here in SoCal ]
most of the people i know in Socal think you are a numbnut dude;-)
Ivan
mysocal911 10-08-2022 02:26 PM
[QUOTE=proporsche;11817055]
Ivan
Right, and many Porsche dealers here for technical support & parts too!
mysocal911 10-08-2022 02:41 PM
Ivan
Your shop, right?
http://forums.pelicanparts.com/uploa...1665268551.jpg
http://forums.pelicanparts.com/porsche-911-technical-forum/1022364-bohemia-911-carrera-4.html
Install DC aircon systems there too?
Nditiz1 10-08-2022 04:03 PM
You getz good internetz?
http://forums.pelicanparts.com/uploa...1665273805.jpg
Tremelune 10-10-2022 10:15 AM
mysocal911 is lorenfb
He gets banned here on the regular...usually for two very specific hangups: capacitive discharge ignitions and air conditioning. It's wild.
winders 11-15-2022 11:06 PM
Well, it looks like I need more than 55 amp alternator for my race car. This alternator looks like a fantastic product and I will be ordering one later this month.
Jonny H 11-16-2022 12:54 PM
Shaft and bearings rated to 18,000 RPM (alternator speed) so all good for race applications.
Brookieslayer 11-16-2022 04:25 PM
Electric heat... possible availability
Good evening,
Can you advise an approximate timeline that you may have the electric heat ready for purchase?
will the heat use the same blower as the AC system to work?
Looking forward to the innovation on this one!
winders 11-16-2022 05:38 PM
Good to know! What are the shipping times from the UK to California these days?
Jonny042 11-17-2022 03:58 AM
I don't tend to think that racecars need that much (electrical) power? Many vintage cars don't even run charging systems and will run all day at a dead loss from the battery. Or it just a matter of the accumulated needs of loggers and ecus and twin plugs and cool shirt or whatever?
If I was racing I would be seriously concerned about reliability and I am sure the CR unit is one of the few choices you can make that's a known entity assembled properly with quality components.
Jonny - what is the weight of the alternator?
Jonny042 11-17-2022 04:07 AM
Originally Posted by Brookieslayer (Post 11849590)
Good evening,
+1 for just enough electric heating element in the blower unit to take the chill off and de-mist the front windshield. 1000W should do it easily.
Paired with electric seat heaters (which are cheap, light, take up no room and apply heat directly to the body) this would be the ideal solution for heat in a 911 Hot Rod that will occasionally need to be driven on a cool morning or a rainy day.
Brookieslayer 11-17-2022 04:46 AM
My thoughts exactly!SmileWavy
Joesmallwood 11-17-2022 04:48 AM
Same page!! Heated seats and a little warmth to deal with the foggy windshield.
hannu_911 11-17-2022 09:56 AM
Heated seats and windshield are even better, no need to warm the cacin.
Jonny H 11-17-2022 10:47 AM
Usually 2-3 days. Occasionally snagged in US customs but generally that's on the larger shipments.
winders 11-17-2022 11:56 AM
Well, when you factor in high power inductive ignition systems, ECUs, high pressure fuel pumps, cooler pumps, cooling fans, air compressors, cool shirt systems, etc., power needs tend to be large.
I am looking at the Classic Retrofit alternator precisely because it looks to be well made and will run cooler than any 3-phase Factory style alternator I could buy. I won't need 175 amps, but 55 amps is probably not enough and I wouldn't want run at near 100% capacity if it were.
winders 11-17-2022 11:57 AM
Thanks! I will be ordering one next in 10 days or so.
chrisbalich 11-18-2022 12:35 PM
JonnyH,
I've been through this thread once and would like to clarify.
Is the alternator on your site the same as the WOSP alternator available from Pelican?
Thanks in advance!
Jonny H 11-19-2022 07:14 AM
Originally Posted by chrisbalich (Post 11851362)
JonnyH,
Thanks in advance!
Yes it is but we supply the uprated power and ground cables with ours within the price.
winders 11-22-2022 01:34 PM
Ordered!
winders 11-24-2022 09:57 AM
Had to pay import duty…
