Thanks. The flange is is about 3.98 inches which is 101.09 mm.
Jason |
gearhead
Yep. It will be 100mm bolt center to bolt center.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
I can measure but I imagine it would be much less that 100 mm bolt center to bolt center.
Jason |
That's OK, they won't be 108mm, which are the larger, more $$$, flanges used in '85/86 Carrera models.
Keep the Shiny Side UP! Pete Z. |
OK, that makes sense. I will pop the cover this week and report back, possibly even today. Out of curiousity, why do I need to pull both flanges to remove the cover?
Thanks, Jason |
gearhead
Because the other flange will be holding the differential into the case. You won’t be able to inspect the ring gear from the backside.
gearhead
Way more info than you need but starting a couple pages in there are good pictures and explanations about this gearbox.
http://forums.pelicanparts.com/porsche-911-technical-forum/975965-915-rebuild-itb-efi-project-here-we-go.html
I was able to pull the differential today. The oil is clean and all looks well to me. Here are some pictures:
Thanks, Jason |
It's a major expense to replace the ring & pinion if damaged or badly worn.
Jon B. Vista, CA |
Did you turn the head of the pinion shaft in order to inspect all 8 teeth? A bit of aerosol cleaner will help you inspect, with all the oil it's hard to see some of the bits!
BTW; don't set the diff assembly on those carrier bearings! Always use one of the axle flanges and set the diff on it...
Keep the Shiny Side UP! Pete Z. Last edited by Peter Zimmermann; 03-20-2018 at 04:00 PM.. |
I already reassembled the diff. Yes, I spun the pinion and there is no pitting or damage. I can break it down again in necessary. I have lots of experience looking at other transmission and transmission parts, just no Porsche specific parts. Point noted on the bearing surface.
Jason Last edited by SuperNovaSS; 03-20-2018 at 04:32 PM.. |
gearhead
Prospective buyers will want to see for themselves. It’s worth your time to pull it back out and snap clean closeups. It’s the difference between a $1500 core for sale and a $2500 one.
Fleabit peanut monkey
Nice work, Supernova. Wish all threads had an OP with SN's diligence. FWIW and off topic, my 69 AMX 390 had a T-10.
1981 911SC Targa |
Aw, crap. I was going to offer SS $800 and pay shipping, but...
I don't think this is the "Hans Herrmann oops Furhman" assembly you are looking for. ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/529135-what-kind-engine-do-i-have.html
1981 911SC Targa Last edited by Bob Kontak; 03-20-2018 at 07:05 PM.. |
Thanks guys. I can’t thank you enough. When I’m asking all these questions, the least I can do is get back to you with the info you ask for. I will get some brake clean and pull the diff out again for some clearer pictures. As I said, I looked it over well but I’m sure I buyer will want to see for themselves.
Jason |
gearhead
I want pictures of the Nova.
It hasn’t seen the light of day for awhile. Kids have taken priority. Hopefully I can get it out of mothballs soon.
Jason
gearhead
Cool. Thanks for sharing.
Will you accept an offer for the early Bronco? Tell me what year it is, and if it runs...
