Fuel line compression fitting leak
A buddy needed to replace some intake components on his '91 964. As a result, some fuel line unions had to be undone.
Upon reassembly, the fitting in a line between the fuel rail and the fuel pressure regulator (FPR) get damp with a periodic drip as soon as the EFI is pressurized.
The union is at the FPR. Both surfaces are free from any visual defects. It is damp regardless if it is mild-tight or super-tight.
It is a compression fitting. There isn't much to service here. What is a method to resolve? Start replacing parts? Any other solution?
In an effort to not disturb the two (of three) dry fittings on the FPR, trying to replace the hose first seems logical.
When these types of unions fail, what side is typically the side of the problem? The line (male side) or the female side (FPR in this case)? Both?
Thank you.
Old 03-18-2018, 08:02 PM
old man neri's Avatar
Step one I would unscrew it completely and screw it back on making sure it goes on straight. Sometimes they just need a reseating.
The 964 board might give you better advice.
Old 03-19-2018, 04:24 AM
Just looking for guidance and general experience resolving compression fitting faults. They just happen to be on a 964.
Old 03-19-2018, 12:09 PM
BoxsterGT's Avatar
Porsche Crest
I use compression fittings all the time, but they are Metric, not a close USA aftermarket fitment that some shops offer.
Perhaps I can help. Post some photos or email me. NO pm's.
Len at Autosportengineering dot com
Old 03-26-2018, 11:15 AM
BoxsterGT's Avatar
Porsche Crest
Did this get repaired?
Tell us how.
Old 04-18-2018, 05:41 AM
Trying to reach Len. PMs full. Email bounces. Please contact me at sarodude at yahoo com
Old 04-28-2018, 05:22 PM
DerkPerk's Avatar
Len’s new Email
Len.cummings@verizon.net
Old 04-28-2018, 06:53 PM
