Brake job in 2 phases (R & F)- dumb?
Hi gang, first post here!! After 4 years of looking, I just picked up a new to me '81 SC with somewhere between 177k and infinity miles (broken ODO in 2001, elderly owner that let it sit for at least a few of those years). Pic below with my E30 5 speed sedan - which I'm planning to sell to finance 911 projects.
I'm planning on doing a brake job this weekend. Will replace rotors, soft lines, and rebuild all calipers (at least one is sticking). My question is: Does it make any sense to do the job in two phases, starting with the rears, and tackle the fronts the next weekend? That would free up a little time for other urgent projects (some CIS sorting, lighting). I also only have two jack stands, so would save me buying two more for now. If I R&R and bleed the rears, drive it for a week, and then do the fronts, will the whole system be effectively bled and flushed, or will I have to redo the rears anyway? One more thing - is there anyone in the central LA area with a pressure bleeder they would be willing to loan for a weekend or two in exchange for a six pack? Thanks in advance for the thoughts. I have already been loving reading this forum - amazing community and glad to be a part of it! http://forums.pelicanparts.com/uploa...1522431298.jpg |
Doing it in two sesions is not a problem. And if you change the brake fluid at the rear first than that's okay to. It doesn't travel around, it just moves a bit back and forwards.
Make sure you read the threads on this and follow the tip to slightly depress brake pedal before disconnecting lines to minimize fluid loss. Once you disconnect the line, plug the opening for additional protection against fluid loss. After you finish the first corner, go ahead and bleed. You'll only need to clear the air out of the new lines and caliper. Do this for each corner.
Note that to replace front rotors you will need to pull the hubs, so naturally this is a good time to replace front wheel bearings. Or at the very least you'll need to clean, inspect, and repack them. |
Yes, to do it in phases as you are thinking, is fine. And the slightly depressing the brake for the rear is a good idea.
But after finishing the front, I would highly recommend completely flushing the brake fluid anyway. |
I think I'll do the fronts brakes and wheel bearings in weekend 2. Putting the bearing order in with our host now, and seems like you need: a) bearings inner and outer for each side (4 total) and b) seals. Newb question again: Do the bearings come with the races, or do you have to purchase those separately? I see the removal/install of the bearings and races are separate steps, so are they sold separately? This is my first bearing foray. Thanks again! |
The front wheel bearings come with the outer race as a set. However the outer race is not captured so is removable from the bearing.
The outer races will be a press fit into the hubs. Since the front hubs are aluminum, heat them in an oven to around 375* and the races should just about fall out. You need to be very careful when R&Ring the outer races as it is easy to damage the aluminum hubs. There is a DIY article about this here. https://www.pelicanparts.com/techarticles/Porsche_911/SUSPEN-Front_Wheel_Bearing_Replacement/SUSPEN-Front_Wheel_Bearing_Replacement.htm |
Thank you all!
Your pedal should be rock hard when air is gone. I drove mine a long time with less than optimal until I got down with my bad self and got angry. Then I got the air out. |
Careful what you are getting yourself into. |
I had no idea that front rotors on a 911 were such a major job.
Looks like I will have to take it to a shop when that time comes. Hubs, bearings, races, pressing are all above my pay grade. |
Something that is often missed when it comes to brake jobs is to make SURE that the brake pedal has a firm feel. This is the same when it comes to doing left or right first. Air in the system can cause a soft pdal.
If the car has air in the system it will NOT have brakes. Ask anyone who has worked in a garage about brakes and the pedal going to the floor. |
take the bimmer to harbor freight and buy two more jack stands. you can't drive, maintain, or call a 911 a project car with alligator arms...
it's a pain to flush rebuilt calipers and you will need all four corners in the air a couple times. |
I found the most annoying part of the front rotor is removing the front caliper without opening up a brake line. |
https://farm1.staticflickr.com/869/2...9c553da864.jpg |
Oh and don't forget to order some new handbrake shoes.
And by the way, a pressure bleeder isn't really needed. I've had success with a gravity bleed, as I learned from the board. |
You are going to need a special tool to get the front bearing cap off without destroying it. Here is a thread on it
http://forums.pelicanparts.com/porsche-911-technical-forum/183349-removal-dust-cap-frt-wheels-bearings.html |
I just knock off the cap with a brass hammer. Takes 10 seconds.
| All times are GMT -8. The time now is 08:37 PM. |
