KYB shocks - at a VERY reasonable price
As I've written elsewhere, I'm currently do a "refurbishment" of my 1967 912 Targa.
There's roughly 100,000 miles on my car; 8000 on "The Maestro" engine. The new rear pans are in, as is the front suspension pan. The entire front suspension was removed to put in the new pan. While it was out, I took a long, hard look at the shocks. The towers are painted red - I assumed Koni. Wrong. That was evident when I looked closely - some dolt in the past painted the shock towers red - without first cleaning off the undercoating. Grrrr. The shocks themselves where bad, but with 100,000 miles on 'em, they were tired. I started looking at Koni, Bilstien, and Boge. Boge front struts are NLA, and Koni or Bilstiens looked like they'd be $500 to replace fronts and rears any way you looked at it. Surfing, I checked out Zims (they advertize in Excellence and other Porsche mags). I typed in the specs for my car, hit "front Suspension" and they showed KYBs. I scrolled down the list of offerings. At the bottom "4 piece KYB set, front/Rear $160". I thought I was reading it wrong. I wasn't. I clicked through it click, click, click. They came yesterday. 2 strut cartridges, 2 rear shocks. $160. You can't beat that. Sure, KYB's don't have the cache of Koni or Bilstein, but at that price, I can replace them three times for what it would cost to put on Koni's aor Bilstiens. Enough blah, blah. It's time to put 'em on the 912. |
1982 928 us
bringing up the past there 248.00 in 2010 from a 2002 post. but nice still to even be able to find the cheaper option.
Zims is "ok" I don't like that they charge "Handling". and we here have to pay tax in TX. I found them also at Seirra Madre for the same price, but for me no Handling or Tax. Also O'rielly's Auto Parts carries them too. Rears are another story. Now where did you get your control arm bushings?
The only problem I had with KYB shocks was at the rear where they raised the ride height by about an inch. Other than that, they weren't bad and the price was right.
Another consideration for Targas in particular is that due to increased chassis flex, gas shocks may not the best choice period.
Personally I found Bilsteins to be a significant improvement over Boges on my '66 coupe. I used KYB's on a truck and they lifted it an inch as well. Do they still come pre-compressed with a release string once you get them in place?
Rick Becker 912 owner since 1977 PCA 912 & 912E Register Advocate, 912 Registry Member #0001 http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register Last edited by Rick Becker; 04-20-2010 at 02:30 PM.. |
I found they ride as if you replaced the shock with solid steel rods...... not very well AND they mess with the ride height as mentioned. Get what you pay for....
Brgds, Peter Baldauf 1967 912 1988 911 vert 944 TS 1969 911 E 1956 356 Conti 1983 911 SC |
1982 928 us
well a plus on the ride height its weighter t4 eng, but riding like steel rod, i got those already, all four shot.
Does anyone know a good source to locate Bilsteins for a 67 912? I've been looking and so far have only been able to find them for the rear.
Many thanks in advance, Chall Sent from my iPhone using Tapatalk |
Bilstein for 912s
@Chall - In the 1980s Bilstein made the P-111 shocks for the front of a 65-68 912. I understand the current part number is P36-0111 front. They're available from Pelican and elsewhere...
Is your 912 a coupe? Some believe gas shocks should not be on early Targas... Bilstein's contact page: Contact Bilstein
Rick Becker 912 owner since 1977 PCA 912 & 912E Register Advocate, 912 Registry Member #0001 http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register |
Perfect, thanks so much, Rick!
Mine is a coupe. I've got the Bilsteins on the way. Chall Sent from my iPhone using Tapatalk |
There was a Porsche of America publication first issued early in 1967 as a bridge between problems found at the factory and the published service bulletins, called the Pit Stop. The very first edition of it stated, "Targas should not be operated with Goodyear Grand Prix tires, nor Koni shock absorbers. Details later." Generally the "details later" were published in a service bulletin.
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
