pud pud is offline
Porsche 912 solex carb
Hi all. I have a 1969 targa 912 , I ran out of petrol , re filled and turned on the electric fuel pump for e few seconds without the engine running , checked the carbs and noticed some fuel possibly coming out from the butterfly spindle , is this a problem , thanks , Andy
Old 11-10-2016, 05:19 AM
WFBowen's Avatar
Andy:
I'd guess that your float needle valve failed to close and fuel ran into the throat of the carb. Might be time for a carb kit & cleaning. When carbs get fuel after running completely dry the floats sometimes stick in the open position. Once it's running again spray a little carb cleaner on those throttle shaft bushings & listen for a change in RPM. They should be airtight & are a very common source of rough running motors.
Bill
Old 11-10-2016, 07:50 AM
pud pud is offline
Porsche 912 1969
Thanks bill, I have run the engine for a short time and the petrol on the outside of the carb does go , I have a problem with the engine running rough at the moment , I have not long had the targa , it seems to be missing causing the engine to rock from side to side , I have replaced the plugs , checked the point gap , but am waiting for new HT leads , should I replace the coil as well, thanks Andy ,
Old 11-15-2016, 11:49 AM
Andy,
Solexes are notorious for wear and leakage at the butterfly spindles; the folks at 356 Carburetor Rescue just remanufactured mine, and they're awesome now. Here's their link:
Page Title
Rick Becker
912 owner since 1977
PCA 912 & 912E Register Advocate, 912 Registry Member #0001
http://912register.pca.org | www.facebook.com/PCA912Register | Twitter: @PCA912Register
Old 11-15-2016, 01:47 PM
pud pud is offline
I have now removed one of the carbs and noticed one of the fuel delivery tubes on the top is blocked and also the float has fuel in it ,
Old 11-18-2016, 05:42 AM
WFBowen's Avatar
Actually great news - The float no longer does its job & the accel. pump is no longer delivering to a cylinder. Time for at least a teardown, cleaning, kit & replacement float.
Bill
Old 11-18-2016, 07:18 AM
pud pud is offline
Soled carbs
Hi bill , thanks for your advice , I have ordered a gasket and washer set , I will go through the carb and clean all the jets etc , not sure what to do about the float , I'm thinking once I get the fuel out of it maybe try and repair it ,
Old 11-18-2016, 11:53 AM
Cobra06's Avatar
New floats are about $25.00, if you patch them and change the weight, could cause you problems
Old 11-21-2016, 07:38 AM
pud pud is offline
Hi , cobra06 , I heated up a screwdriver and melted over the small pin size hole , hopefully will be ok , if I have trouble do you know where I can get a new float for the solex carb , I'm in the uk , ps the carbs are solex 40Pll cheers , Andy
Old 11-27-2016, 03:12 AM
Cobra06's Avatar
Try Eurocarb, they're in the UK. Or ALFA1750 on eBay, he's in Italy and has pretty much all of the SOLEX 40 parts
Old 11-27-2016, 06:00 AM
pud pud is offline
Porsche Crest Solex carbs
Thanks cobra, I have ordered a new float from euro carb , thanks for the help ,
Old 11-27-2016, 09:50 AM
pud pud is offline
This is driving me nuts , I've just tested the carbs by turning on the electric pump for a while , I'm thinking petrol will fill the bowls and then the petrol will be cut off by the petrol valve , but no , petrol is filling the throats , is this just a case of the shut off not working , ?
Old 01-05-2017, 06:15 AM
Running too much full pressure with an electric fuel pump will easily over pressure the float valve (floats). For water ever reason you have the need to use an electric fuel pump then you must install a fuel pressure regulator and dial it down to around 2psi. There is nothing surprising with your situation.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 01-05-2017, 09:30 AM
pud pud is offline
Hi , I have a fuel pressure regulator on and have it set at 2 psi
Old 01-05-2017, 11:34 AM
Excellent!!
Search around on the 912bbs.org for information regarding the difference in the available Solex needle float valves, there is a good and a bad version AIRC.
Jung
'68 912 Coupe
'82 SC sunroof
Old 01-05-2017, 04:18 PM
The 'good' (stock) float valves are 1.75 and have a spring-loaded roller ball in the plunger; the 'bad' are 2.0 and have solid plunger.
Photo: 'bad' on left, stock on right.
Peter
Old 01-06-2017, 04:25 AM
pud pud is offline
Hi I have just bought 2 new float valves , looks like the one on the left but has roller ball on the pin , hope they will be ok ,
Old 01-06-2017, 09:50 AM
The orifice size is critical too: make sure they are stamped '1.75' and not '2'.
Peter
Old 01-06-2017, 11:15 AM
pud pud is offline
Thanks peter ,
Old 01-06-2017, 11:39 AM
