3D914's Avatar
Amark,
Thanks. I always have to go look at my manual to remember straight. I'll edit the message in case someone else needs it.
Regards,
Gerard
74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
Old 03-12-2003, 04:05 PM
Bubbling well's Avatar
Cooling Fan Difference
Originally Posted by Jared at Pelican Parts View Post
Keep in mind that you also need to change the cooling fan to accommodate the pulley for the compressor belt. You will also need to relocate the ECU unit as it will not clear the compressor when mounted in place. also believe you will need to install a throttle kick-up switch that will increase the idle speed when you kick on the compressor.
Question on this old post.
So the cooling fan for a/c cars has a shorter height than normal cars?
Thanks,
bw
Old 12-25-2013, 11:43 PM
3D914's Avatar
Thanks,
bw
bw, IIRC the fan is the same - its just that the pulley for the A/C sits behind the fan - so it has to be removed. I also did not have any of the other issues jared mentioned.
Gerard
Old 12-28-2013, 10:24 AM
On no! it's still there!!!
Thanks for your reply. I've actually left the a/c pulley in there. I think the pulley isn't perfectly aligned with the alternator pulley. Should I change it with a regular washer? Wondering if adjusting the alternator could compensate the misalignment ....
Also, can I change the it with the engine still in the car by removing the front engine sheet metals?
BW
Old 12-28-2013, 07:39 PM
914 Geek
Most 914s had a flat piece (sort of a washer) between the fan hub and the fan. 914s with A/C replaced that with the pulley for the A/C. That is behind the fan.
The front of the fan has the pulley that drives the alternator. It has nothing to do with the A/C pulley, except if the A/C pulley is left out and not replaced with the washer, the fan won't line up with the alternator pulley.
Here is an exploded drawing: http://www.pelicanparts.com/914/parts/engine/aircooling_large.htm
The washer is part #15, and that is the part that gets replaced with a pulley to run the A/C. The pulley part of the fan is #12 in that diagram, and that pulley holds the alternator belt. I hope that helps you visualize what goes where.
--DD
Old 12-28-2013, 10:21 PM
Here is an exploded drawing: Pelican Parts: Porsche 914 Air Cooling System
--DD
Thanks DD for the information. Now I can clearly picture what's there.
So I heard the a/c was a dealer installed option for 914 back then. Did they install some washers underneath the alternator pulley in order to line up with the cooling fan pulley? What's their trick?
Now I have to think if I can install the washer( have one on my old engine) w/o taking the motor out of the car. I have never taken the engine sheet metals off with the engine still in the car.
bw
Old 12-30-2013, 10:04 AM
914 Geek
The AC pulley replaces the spacer behind the fan. It is the same thickness in the middle, so it does not move the fan forward at all.
--DD
Old 12-30-2013, 04:50 PM
Thanks DD. But sorry, I am confused here. What would be a reason for the misalignment?
BW
Old 12-31-2013, 09:07 AM
914 Geek
What I'm saying is that there should be no misalignment.
--DD
Old 12-31-2013, 11:08 AM
