Original Owner
tsuter's Avatar
914 Cold Start Valve replacement P/N
Help! Where do I get a CSV for a 1973 914 1.7L.
The CSV p/n was 0 280 170 018 or 0 280 170 017
These don't seem to be available anymore anywhere.
But something must have replaced it.
Mine leaks badly.
Thanks,
Thad
tsuter
78 911SC Turbo Targa
Thaaaats Right!!
Old 03-10-2003, 12:44 PM
914 Geek
Have you tried calling?? Unless the part is specifically listed on the website as NLA (and sometimes, even if it is!) there is a half-decent chance that Pelican can get it for you.
Another possible option is to bypass it--run the fuel hose past it, instead of through it--and not bother with it. You can cycle the fuel pump once or twice, then stomp the throttle to the floor with the key on, then crank the starter. That will get extra fuel into the manifolds which is what the CSV does.
If you just drive in the summer, you probably don't even need to do that! Just bypass it and live without it. Remember, it only operates below about 40 F, and then only when the starter is cranking.
--DD
Old 03-10-2003, 01:30 PM
Original Owner
tsuter's Avatar
Unfortunately they were not much help except to say that 017 was discontinued. Didn't even have a picture of the 2.0L one. 0 280 170 015
What I need is one or two fuel connections (not banjo bolt) and a short pintel.
So it does not have to be the exact part.
Pictures anyone?
CSV is for special application purposes so functional equivalency is what is required.
tsuter
Thaaaats Right!!
Old 03-10-2003, 01:54 PM
914 Geek
Ah, I get it. The 2.0 CSV has a single fuel connection--a barbed plastic fitting-- and a longish nose. Not sure about the pintle itself (if I am correct about that meaning the little "needle" in the middle). The nose goes through the plastic spacer that also has the connection to the AAR, which I think is why it is longish.
--DD
Old 03-10-2003, 03:49 PM
Original Owner
tsuter's Avatar
Short nose is what I mean. Pintel probably not the right word. One barbed fuel connection is fine. Are their any pictures of a 2.0 so I can see how long the nose is? The CSV for the 1.7 was about 1/8' inch long.
Thad
tsuter
Thaaaats Right!!
Old 03-10-2003, 05:08 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
maybe you could try a 1.8 CSV. it is an "inline" item unlike the 2.0 which is at the "end of the line".
Old 03-11-2003, 05:36 AM
Original Owner
tsuter's Avatar
The number of fuel connections doesn't matter for me - only the lenght of the "nose". Shorter is best. And a single/multi barb connection(s). No banjo bolt.
Still need pictures of a 914 2.0 or 1.8 CSV that are still available with the bosch P/N.
Thanks,
Thad
tsuter
Thaaaats Right!!
Old 03-11-2003, 06:55 AM
jamcleod's Avatar
since the "nose" basically sticks into the air distributor, i would not think the length matters. it just sprays extra fuel for a couple of seconds when the temp is below a certain value.
Old 03-11-2003, 07:09 AM
Original Owner
tsuter's Avatar
tsuter
Thaaaats Right!!
Old 03-11-2003, 07:14 AM
jamcleod's Avatar
i'm trying to post a pic i found
Old 03-11-2003, 07:16 AM
Original Owner
tsuter's Avatar
CSV
Here is a picture of my application. The CSV "nose" should be as short as possible. Like the 914 1.7 that I used for quite a while. One or two fuel fittings is fine. One preferred.
The P/N pictured is 0 280 170 010 for a 82 Volvo and they seem to fail on me faster than the 0 280 170 018/017 for the 914 that is discontinued.
Thad
tsuter
Thaaaats Right!!
Old 03-11-2003, 07:26 AM
Original Owner
tsuter's Avatar
CSV w Short nose
Preferred application is 70-73 914 short "nose' CSV.
What is the P/N for the one you pictured?
tsuter
Thaaaats Right!!
Old 03-11-2003, 07:31 AM
jamcleod's Avatar
BOS-0-280-170-026
for an 80-83 air cooled vanagon
why does the length make a difference?
Old 03-11-2003, 07:58 AM
Original Owner
tsuter's Avatar
It's probably more theoretical than practical but I don't like the nose blocking air flow in that pipe and I "think" I get better dispersion with the shorter nose.
Anyway it looks like the long is all thats available now.
What is your source of the pictures and numbers - does it have flow rates?
Thanks,
Thad
tsuter
Thaaaats Right!!
Old 03-11-2003, 08:02 AM
914 Geek
If you're concerned about the length of the nose, you could always make a spacer. That's what the 2.0 has--the CSV pokes through the spacer into the manifold. In the case of the 2.0, the spacer also has the inlet for air from the AAR.
--DD
Old 03-11-2003, 08:15 AM
Original Owner
tsuter's Avatar
Picture of this CSV?
Cold Start Valve, 914 1973-76 2.0L BOS 0-280-170-015
tsuter
Thaaaats Right!!
Old 03-11-2003, 10:07 AM
914 Geek
Just about identical to the pic Jmacleod posted.
--DD
Old 03-11-2003, 11:29 AM
Original Owner
tsuter's Avatar
"Just about"? Which has the lower fuel flow rating?
0 280 170 026 or
0 280 170 015
If 015 is for the 2.0L what is the motor in the 74-83 Vanagon?
I'm not trying to be difficult here but I need a CSV that is functionally equivalent to the 70-73 914 1.7L
I.e., same flow at 3.5 bar.
tsuter
Thaaaats Right!!
Old 03-11-2003, 11:34 AM
jamcleod's Avatar
80-83 air cooled vanagon is a 2.0 Liter L-jet type IV
virtually same L-jet as on 1.8L 914's
i have never seen specs on a CSV, not to say its not out there of course, but i bet it's more trouble than its worth to worry about.
Old 03-11-2003, 11:40 AM
914 Geek
I don't know any of the specs on the flow rates. You asked about a pic, and the 2.0 CSV is almost identical to the one in Jamcleod's picture. The visible difference is that the hose barb is below the electrical connection, not beside it.
--DD
Old 03-11-2003, 11:46 AM
