sjhenry1075's Avatar
backfire?
Hi everyone,
So I'm still new to the 914 scene and I'm still learning how to fix it! Currently my issue is with starting. When cranking the engine, it seems as if I'm getting a backfire through the intake? I read that the distributor could be incorrectly installed, but won't it only go in one way? I also read that it could be a timing issue, but don't you have to have the engine running to set the timing?
I appreciate your assistance and patience. I posted this on 914 world as well, but thought I'd post it here because the more help I can get the better!
Thank you!
Steven
Old 06-28-2019, 12:41 PM
914 Geek
1- The distributor is supposed to only be able to go in one way. We know quite a few people who have managed to do it, though.
2- You can do a static timing to the engine. Make sure that the spark fires pretty close to TDC, which should be good enough to start the motor.
--DD
Old 06-28-2019, 05:59 PM
^^^ And let's not forget to ensure the wires are going to the correct plugs in the proper order...
Old 06-29-2019, 07:10 AM
