I'm running 8.3:1 static with a web cam #73. I have the .060 copper head gaskets.
Ed |
Thanks Ed...
So what made you go with a non-stock cam? Is the .06 dim before or after one torques the heads? |
The #73 has a little more lift and good duration. It has a nice strong torque curve like the stocker.
The .060 is the material thickness prior to torquing the heads. Ed |
No biggie Mike. My C/R is 7.7 : 1 and I run no gasket between the cylinder and head. I am using a .060 cylinder shim to achieve the desired C/R. I've had to many people say that the head gaskets are not good to run. I definately would love to hear a different opinon. If I need them now is the time. Oh, I'm running a brand new stock cam. I chose the stock cam to elimenate any doubt about what if anything could be causing problems with the motor while testing and evaluating the Turbo setup. I used the KISS method on the build. Once I dial it in and am happy, I'll probably tear it down this next winter and put a different cam in and probably stroke the motor..78x96. There is no replacement for displacement!
Randy |
All great info...
No case splitting for me, I don't need anymore excuses for not having a running 914, LOL Stock cam, but I am running Pauter Roller Rocker Arms for a little more lift...doubt it'll help much, but I see no harm in it. I'm still trying to decide where to put the intercooler, I wanted this style, but got out bid for it on evilBay http://us1.webpublications.com.au/st...5/0527_7mg.jpg My turbo is a lowly IHI unit for mid-80's Subarus....but it'll work for now until I can get a good deal on the proper sized T3 |
What type of external oil cooler is everyone using, and how are you plumbing it?
Randy |
Is it obvious to everyone out there that Evil Ed is my hero? :-)
I did it to see if it could be done, he took it to the next level and did it better IMO. CIS rules. The stock cam works very well with a turbo and will pull harder from around 2500 or 3000 rpm (depending on the turbo) all the way up over 6000 rpm. A slightly hotter cam will work better to a point. High lift will be a good thing, but not too high. Also Anything 270 degrees are a no no I've been told because some of the boost charge will go right out the exhaust pipe, never tried it myself. |
Sammy, if Evill Ed is your hero, then EJM must be a demigod!! ;) No offense, Evill, but I thought that EJM's setup was even better than yours! (Definitely more sophisticated, at least.) He is also running CIS, but his CIS is a wee bit different from Evill Ed's. And it's all factory bits, too! (Some from the Audi factory, some from the VW factory, some from the Volvo factory...) --DD |
I found this photo. Its an Ozzie set up.
2 liter VW Type 4 engine adopted with Porsche cooling system, digital injection and ignition system, Twin turbo with Catalytic converter closed loop. The engine has been tested on engine-dyno with 180 HP. http://forums.pelicanparts.com/uploa...FOUR TURBO.jpg |
| All times are GMT -8. The time now is 09:42 PM. |
