canna change law physics
red-beard's Avatar
Question Raising a lowered 914-6
I just had a once over on my new baby yesterday, to see if there was anything wrong beyond what I already knew. The mechanic (as a couple of other people have said) the car has been lowered. And he said that the lowering was an adjustment, not a change of parts.
I'd like to get the car back to stock height (I'll scrape the front valance a little less often). Anyone know how to make the adjustments?
James
Old 03-29-2002, 05:47 AM
914 Geek
At the aft end of the front torsion bars are some cam-shaped thing with bolts through them. Turn the bolts and you adjust the front ride height. I forget which way is which, though.
Haynes has a porcedure and pictures.
The rears are not so simple...
--DD
Old 03-29-2002, 09:01 AM
red-beard's Avatar
Thanks! I'll dig around for my Haynes book.
What do you think was done to the rear to lower it?
And does someone have a height number to work towards?
James
Old 03-29-2002, 09:07 AM
If the rear is low, it could be a few things. 1. If it still has the original springs they will probably have sagged by now. I know mine did and when I replaced them with new Weltmeister 100 lb springs the rear ride height went up 1-2 inches! 2. The PO replaced the springs with shorter higher rate springs. 3. Or if you're lucky the PO put in shocks with adjustible spring perches which means you can reset the rear height. As you know, with fixed springs the only hay to alter height is to alter springs (or vehicle weight!).
Mike
Old 03-29-2002, 10:16 AM
turning in (clockwise ?) raises the front. don't do this with the weight of the car on the tires.as your car sits, is the front end drasticly lower than rear or does i sit fairly level? if your rear coils are stock you might find some green paint marks on them
Old 03-30-2002, 12:48 PM
red-beard's Avatar
The front and the rear seem to be about the same heigth. I'll do some measurements. I'm going to try raising the fron end, next weekend. I have the semi-ex-GF in town. She did put up with being driven from San Diego to Oceanside in the 914/6. She is still afraid of the cars!
James
Old 03-30-2002, 04:04 PM
Jim Smolka's Avatar
Cool
Red-Beard,
I would not raise the car for the your friend's sake. Tell her that it is not every car that you can read the tire size of the SUV stopped next you at a light.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 03-30-2002, 06:10 PM
Zeke's Avatar
It isn't just scaping the front. It'll ride better if it's up a little closer to stock. It's an old car. If it hasn't been fitted w/ new shocks in a while, you'll want to do that.
People don't understand how choppy the freeways are here in CA. Some of that road up to Oceanside is pretty nice though.
Old 03-30-2002, 08:09 PM
Bai Bai is offline
Hi hello any idea how to adjust the height of the rear part of my 914 pls,mine is too low ,thanks for your help
Old 12-22-2019, 01:16 PM
914 Geek
To change the rear ride height you either need to replace the rear springs, or move the lower spring perches. The latter is not possible with most shocks; you must have one that has provisions for that or you must have a threaded-sleeve "coil-over" set.
Several Koni shocks have adjustable spring perches, and there may be a couple of Bilsteins that also do?
The typical solution is actually to change the front ride height so it looks good with whatever height the rear has settled into.
--DD
Old 12-22-2019, 03:11 PM
When you change the ride height you change all the alignment settings.
Old 12-22-2019, 05:13 PM
So, I believe I can mount a 914-6 flywheel on a 2.7 911 engine, is that right? But how about using a 914-6 clutch? Can a 914-6 clutch handle a 2.7? By "handle" I mean for street purposes, not crazy stuff.
(holy smoke - 18 yr old thread!!!)
Reparations for neanderthals!
'70 914-6, 1965 Mustang GT - RIP, '74 911, '01 Box S
'12 Ducati 848 Evo - RIP, '16 Yamaha R1, '13 Aprilia RSV-R
Old 01-24-2020, 12:35 PM
914 Geek
Yes to all three of your questions. The 914-6 flywheel is pretty much just a 1969 911T flywheel with different marks on it, in case you can't find a specific 914-6 one.
--DD
Old 01-24-2020, 05:41 PM
Thank you!
Old 01-24-2020, 06:14 PM
