Any weights in my dizzy?
Car is a 2.0 L 912E with the 914 motor.
In the cold weather, my revs stay up between shifts - like 3,000 rpm. A former 914 owner says he fixed this problem by lubing the centrifugal weights, as they were sticking. I think his car was a 1.7 or 1.8. I removed the cap, and looked in two books (factory and Chilton) but can't find a schematic of the distributor interior showing the weights. Had the factory gone to electrical advance by 1976? And, yes, I have the vacuum pot and related hose in tact. Thanks in advance Bill K |
The weights are there. You have to partly disassemble the distributor to see them. They are located under the points plate. I know the points plate comes out the top of the distributor body, but I don't remember what holds it in place.
--DD |
Thanks Dave. I was hoping it would be an easy fix :( without pulling the guts out and resetting the dwell/timing.
Bill K |
| All times are GMT -8. The time now is 01:38 PM. |
