-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Heater Lever Indicator Light (http://forums.pelicanparts.com/showthread.php?t=1072553)
LThibeault 09-08-2020 02:11 PM
Does the Indicator light require a ground wire from the backside of the indicator?
Mine has 1 wire connected to the light but I do not see a ground wire on the other side of the bulb?
Dave at Pelican Parts 09-08-2020 03:09 PM
Yes, it does require a ground. On my car, which had a center console, the ground pin connects to a short brown wire that has a ring terminal that goes over one of the mounting screws for the light base.
--DD
