Will not shift into gear
My 1973 914 1.7l will not shift into gear. The shifter floats rather than gates between gears. Any idea what causes that issue?
Old 04-28-2021, 01:56 PM
John Rogers's Avatar
I would figure bad/worn out bushings. There is one at the front, one on the middle joint and one at the rear at the transmission case. Put the car on stands, lay under the rear end and have someone shift the gears and watch what the linkage does.
John
Old 04-28-2021, 07:06 PM
Emo993's Avatar
Yup as John Rogers said, remove the black plastic cover on the side rear of the transmission. And with a friend moving the shift lever you will be able to see or feel where neutral is and the three gates. Mark
1974, 914-6 GT Tribute
2007 Cayman S
1998 993 Carrera S, speed yellow (Yellow Bird) gone but not forgotten.
2017 Golf Sportwagon 4motion
Exclusive source for the 914 Umbrella and Service cover
Old 05-29-2021, 04:47 AM
Check the plastic ‘cup’ that is supposed to be inside the last metal piece that rides on the ball of the shift mechanism on the trans. The plastic cup deteriorates over time and you can’t feel gear selection.
Tony G
2000 Boxster S
Old 05-30-2021, 03:36 AM
Check all the linkage from the shifter back to the transmission. Check the cone screws. If they back out the linkage will come apart.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 06-03-2021, 10:59 AM
