kellzey's Avatar
Ahhh.. the magic of POR-15
I had some surface rust on the floorpans underneath all that nasty tar...
Total time spent removing tar, grinding rust, and grinding away seam sealer on the floors and firewall = 40 hours.
Next. I applied Marine Clean and Metal Ready from POR = 1 afternoon (about 4 hours)
Finally a coat of POR-15 semi-gloss. It's still drying here, but it's so nice looking! = 1 hour.
I think this will be highly worth the effort for the final project.
Regards,
Qarl
Old 04-27-2003, 05:47 PM
jamcleod's Avatar
Send a message via AIM to jamcleod
outstanding.....
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 04-27-2003, 05:53 PM
mike95125's Avatar
WOW!
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 04-27-2003, 08:41 PM
scg scg is offline
scg's Avatar
Outstanding.
Have you given any thought to doing a little rewiring of that ugly logic relay...or has the seat belt "patch" already been made (can't tell from the pic)
Scott
74 914-6 2.7
Old 04-27-2003, 08:59 PM
korijo's Avatar
Nice...
Now I remember what it looks like Havent got that far, yet...
Karl, did you brush or shoot that on?
Dave
Korijo
73 Olympic Blue 914 1.7L (2L /4 back in progress)
69 Highlander Bug 1776
93 GL EV 2.8L The Van ™
914club.com Member #914
Old 04-27-2003, 11:15 PM
korijo's Avatar
Forgot my pic of Por Magic
Dave
Korijo
Old 04-27-2003, 11:21 PM
I've used por-15 for years...I love it! As a matter of fact I'll be brushing some on today! Looks great, did you use heat to remove the tar board, I find that a light torch helps remove it.
Randy
2011 Chevy Silverado (The Hauler)
1984 911 Carrera summer daily driver
Old 04-28-2003, 05:04 AM
After stripping and painting with POR-15, what do you do with the pan? Any sound proofing? Or just carpet?
Mike
Old 04-28-2003, 06:24 AM
Mike, I went through this recently myself. I was thinking that I have pictures just like those that are posted here. I used this stuff called Dynamat. It's a soundproofing material that's similar in consistency to the tar that was there, except it has an aluminum backing. It's sticky on one side and you just press it onto the floor. I read that 80% of cabin noise comes through the floor. Of course, whoever wrote that has never driven a 914 with the top off! ************************ carries the Dynamat or your local car stereo shop probably carries it. Performance products had a good price on it though (it's a bit expensive).
'73 2.0 -- Yellow
Old 04-28-2003, 11:28 AM
914 Geek
Do a search around here on "dynamat" and you'll find a number of other, less expensive alternatives that other people have used.
--DD
Old 04-28-2003, 01:10 PM
mskala's Avatar
From the pic it looks like you didn't grind through the factory
primer (grayish) in most places. I thought from a previous thread
that that would not let the POR-15 do it's best. That it should be in contact with the metal to prevent rust spread. Anyway that's how I did it recently.
Mark S.
'70 914-6
Old 04-28-2003, 02:32 PM
I've never used POR15 but a lot of folks swear by it, including my neighbor who restores old Mercurys and Fords. Looks good on frames/chassis parts. I should get some to try. I just finished putting sound deadener (Soundcoat polymer barrier) in my 914 yesterday after doing the whole car inside and out with epoxy self-etch primer. This is after stripping it bare and replacing all rusted steel (or using a rust converter where only lightly pitted). Thought I'd upload a picture to show you.
Guy
Old 04-28-2003, 09:18 PM
kellzey's Avatar
The areas where there was surface rust, I wire brushed a decent amount away from the edge of the rust to the clean factory primer. I ground away all the seam sealer.
That factory primer is bonded there pretty friggin tough. I also don't plan on getting this car wet any time soon, so I'm not too worried about further rust.
Qarl
Old 04-28-2003, 09:24 PM
Where can I get POR-15 and what is the best way to remove the rust and apply the product? Also how do you apply it into the hard to get places like the uni-frame and channels?
Mark
Old 04-28-2003, 09:31 PM
Just type in "POR-15" on your browser and it should be one of the first on the list. As far as rust removal goes, "POR" is short for "Paint Over Rust", so all you really need to do is knock off the big stuff and brush/spray it on. What really amazes me about the stuff is that even brushed on, it looks like it was sprayed leaving almost 'Nil' brush marks. Also, if the metal is prepped correctly, POR-15 is tough as nails!
"Whether you think you can, or think you can't, you're probably right" - Henry Ford
'73 914
'75 914
Old 04-29-2003, 12:14 AM
Not right in the head
nutzforporsche's Avatar
Send a message via Yahoo to nutzforporsche
My apologies for this really stupid post. I hear about this stuff all the time and have no idea where to buy it. Can anyone point out a place or places to get it and a base price for it?
Thanks!!!
stevethacker@earthlink.net
87' 944S
99' BMW 740iL
Old 04-29-2003, 09:18 AM
dman's Avatar
Kelly your car looks great how did you apply the por-15, did you spray it on? Was that a PITA?
83 SC Targa
00 Audi S4,
Toyota parts truck
Old 04-29-2003, 09:38 AM
http://por-15.com/ About $31.00 a quart, I always brush it on, it hardly leaves any brush strokes. I would be afraid to put it in my good gun, because it dries so hard and fast you could ruin your gun if you did not clean it quickly after use with thier special thinner! I've used a lot of their other products, it all seems to be quality stuff!
Randy
Old 04-29-2003, 09:52 AM
andyu911's Avatar
kellzey, I wonder how many quart did you use to cover the floor pan and fire wall? BTW, very nice job.
Andy
'87 Carrera
'73 914 2.0
Old 04-30-2003, 11:09 PM
kellzey's Avatar
Less than 1 quart.
Qarl
Old 05-02-2003, 09:19 PM
