1.7 & 2.0 ECU compatible?
Is the 1.7 and 2.0 F.I. ECU brain compatible with each other?
1973 Porsche 914 1.7L
2002 Volkswagen Eurovan
Old 05-10-2021, 03:52 PM
914 Geek
If you mean will they actually function when swapped, most or all of them will. If you mean are they identical, then they are not--with one exception, the 1973 2.0 ECU is the same as some of the 1.7 ECUs.
The car may not run correctly with the wrong ECU.
See https://members.rennlist.com/pbanders/DJetParts.htm for info about what parts go with which years.
--DD
Old 05-11-2021, 01:32 PM
Tags
1.7l engine , 2.0 , brain , ecu
