1.7 & 2.0 ECU compatible?
Is the 1.7 and 2.0 F.I. ECU brain compatible with each other?
1973 Porsche 914 1.7L
2002 Volkswagen Eurovan
Old 05-10-2021, 02:52 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
If you mean will they actually function when swapped, most or all of them will. If you mean are they identical, then they are not--with one exception, the 1973 2.0 ECU is the same as some of the 1.7 ECUs.
The car may not run correctly with the wrong ECU.
See https://members.rennlist.com/pbanders/DJetParts.htm for info about what parts go with which years.
--DD
Old 05-11-2021, 12:32 PM
Tags
1.7l engine , 2.0 , brain , ecu
