-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   warmed up resistance of temp sensorII (http://forums.pelicanparts.com/showthread.php?t=115775)
914nate73 06-20-2003 09:37 PM
After the engine has warmed to its full operating temp the amount of resistance is 360 this seems low but I have the 73 2.0 that requires the ballast to restrict it even more. Is this reading ok or do I make for an order with Pelican for a new temp sensor II?
By the way this BBS is fantastic!!
Nate
bowlsby 06-20-2003 11:36 PM
Your values are in line with acceptable tolerance...
See Brad Anders great D-Jet pages at:
http://members.rennlist.com/pbanders/DJetParts.htm
pbanders 06-21-2003 07:45 PM
Nate - is that 360 ohms with or without the ballast resistor? If it's with, then it's ok. Without? Too high.
914nate73 06-23-2003 09:39 PM
With ballast resister iy reads 360 ohms. Guess it must be ok.
Nate
