warmed up resistance of temp sensorII
After the engine has warmed to its full operating temp the amount of resistance is 360 this seems low but I have the 73 2.0 that requires the ballast to restrict it even more. Is this reading ok or do I make for an order with Pelican for a new temp sensor II?
By the way this BBS is fantastic!!
Nate
Old 06-20-2003, 09:37 PM
bowlsby's Avatar
Your values are in line with acceptable tolerance...
See Brad Anders great D-Jet pages at:
http://members.rennlist.com/pbanders/DJetParts.htm
Old 06-20-2003, 11:36 PM
pbanders's Avatar
Send a message via Yahoo to pbanders
Nate - is that 360 ohms with or without the ballast resistor? If it's with, then it's ok. Without? Too high.
Old 06-21-2003, 07:45 PM
With ballast resister iy reads 360 ohms. Guess it must be ok.
Nate
Old 06-23-2003, 09:39 PM
