Side window clamp glue?
Has anyone had a side window come unstuck from the cradle it sits in at the bottom. My passenger's side window came unglued and I went to the glass shop to get some glue and they said they used to reglue them with a warranty but they've had so many come back they don't warranty it anymore. Then they recommended trying to get a new one. Can you even get a new window with the bottom part clamped on? I'm sure I could find a used one but mine was used so why would I get another one to have it come unglued? Anyone try to reglue this piece??? If so what did you use?
Alex |
early or late glass? if you clean the channel and the glass well and a bead of silicon should do the trick. kevin
i used silicon adhesive on an early window. it's held for about a year or so now.
doug |
By the way, clear silicone sealant is what the glass companies use to bond the metal channel to the top of frameless glass shower doors, so if it can hold a big heavy sheet of glass from the top it should hold a side glass from the bottom.
Guy |
| All times are GMT -8. The time now is 03:10 AM. |
