-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=7)
-   -   Type-5 powered 914 (http://forums.pelicanparts.com/showthread.php?t=119686)
SteveStromberg 07-19-2003 07:56 PM
Type-5 powered 914
Well I was thinking of going with the Mazda Kzle motor but after looking at all the plumbing and a KEP adapter , I tacked,and am going for the Type-5 Oxyboxer. A little Sheetmetal fitting looks alot simpler than running all those coolant lines. A FAT 911 Shroud and a Pair of 44 IDFs. 2130 cc. and lighter than the type-4. Steve
skline 07-19-2003 09:31 PM
Ok Steve, I am at a loss. What is a type 5 Oxyboxer? Fill me in.
SteveStromberg 07-19-2003 09:38 PM
See:
http://www.gearheads.dk/oxyboxer.htm
mike mueller 07-19-2003 11:15 PM
If I read that site correctly, it's basicly a Type IV engine case fitted with VW Bug Type I heads on it???
I like the idea of watercooled heads, too bad the Wasserboxer heads have the exhaust in the "wrong" location for our 914's.
SteveStromberg 07-20-2003 07:32 AM
Its a Vanagon watercooled motor that is converted to air cooled.it uses Air cooled heads. I am going to use Type-3 heatexchangers and Dansk Type-3 mufflerhead pipes set up and a 911 twin inlet single out let.This Motor allows you to use all the type-1 performance parts. 130 hp is no problem with these motors
http://forums.pelicanparts.com/uploa...1058711403.jpg
This photo shws one installed in a bug for a 914 the cooling tin would be similiar. Steve
[Steve, leave out the spaces in between the "img" tags and the location. --DD]
RD Evans 07-20-2003 07:32 AM
Price Estimate
Steve, what does the price look like for this engine?
waterboy 07-20-2003 09:50 AM
Steve--
I've been looking at the same option and on paper it looks like a good performance/cost ratio. Do you know if there are any engine-mounting issues? Another consideration would be the need for a custom exhaust. One more benefit I can see is that it would make installing a T1 turbo kit a viable option :cool: On the down side, I doubt if it would be PCA legal..
Regards,
BWB
SteveStromberg 07-20-2003 10:49 AM
The exhaust is not a real big deal by going with the T-3 set up the down pipes are flanged to match a Stock two inlet muffler this is where I am going to go two into one then back to a 911 muffler. The stock 2.0 cross bar looks like it will fit. I may change to the early motor mounts in place of the 73 style and solid mount the motor to the 73 bar. Steve
SteveStromberg 07-21-2003 08:54 PM
Thanks to Piledriver and Tuna we have Photos.
http://www.tunacan.net/wasserboxer/914/
Jake Raby 07-27-2003 11:41 AM
I'm doing a T-5 engine right now....
I'm developing mine for high torque in heavy applications, but not for a 914.
The T5 requires ALOT of custom work, and without a lathe and a Mill don't attempt it.
