Poor-sche Lover's Avatar
Dumb Heater Question
As the subject states, here we go.
How do the heater flapper boxes install? Obviously, the j-tubes flare out. Are the levers that operate the flapper on top or on bottom? My car has never had these. They were sitting in my trunk.
Thanks for your help.
Old 07-23-2003, 07:04 AM
jamcleod's Avatar
Send a message via AIM to jamcleod
i think the levers are on the top. you can figure this out by the way the valves have to line up with the tubes to the heat exchangers and the hose to the duct/duct connection to flow the air to the cockpit and the cable wire position.
73 914 restoration project
73 914 2.0 CIS #80
74 914 1.8L L-jet
83 911SC
Old 07-23-2003, 07:14 AM
canna change law physics
red-beard's Avatar
They are right and left hand valve. While they are out, verify operation. I had one fail and it flapped closed. The lever's are definitely on top.
James
Red-beard for President, 2020
Old 07-23-2003, 08:09 AM
John Rogers's Avatar
We have one with the lever on top and one on the lever on the bottom! When you fit them on you will see where the wire to open them comes from near the middle of the fire wall and then manually pull the lever so the flapper opens. As James said it fails shut so you'll be able to figure it out. Heat is nice when we have those cold mornings in San Diego!!! Good luck.
Old 07-23-2003, 08:25 AM
should look something like this.
kevin
Old 07-23-2003, 09:29 AM
HMeeder's Avatar
Both of mine are on the bottom. I wonder if I re-installed them upside down? They both still work in that position though.
Herb
'72 Tangerine 'Teen
2.4 liter aluminum handgrenade
Old 07-23-2003, 10:26 AM
doing it as in my pictures keeps the control arms and cables "up" out of the way
here? not so much i think. high five!!!
Old 07-23-2003, 10:29 AM
M. Hendrix's Avatar
There are no dumb heater questions, just dumb heaters.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 07-23-2003, 11:53 AM
